INTRO PRICING!!! Torque Solution 991 Dog Bone Control Arm Kit!!!
Former Vendor
Price (no $ sign please): $595
Private or Vendor Listing: Vendor Listing
Location (Region): SouthEast
Item Condition: Brand New
595.00 SHIPPED
Torque Solution Dogbone Rear Control Arms
Applications: Porsche 911 991/Turbo/C2/C4 w/ Toe Steer
Torque Solution Rear Dogbone Kit is designed to correct the rear suspension geometry on your lowered Porsche 991. If you are experiencing uneven tire wear due to too much camber this kit will help bring your alignment back in spec for better performance and longer lasting tires. The factory camber adjustment range is not enough to bring your car back within spec after lowering the vehicle. if you plan to track your car or get the full life of your tires these are a must have.
Made of 6061-T6 Aluminum w/ PTFE Lined FK Rod Ends. 4 links total included in each package. Requires NO modification to chassis and is a direct bolt on replacement part. Can be used on daily driven street cars & is highly recommended for Street or Track setups.
- Made out of Lightweight 6061 Billet Aluminum
- Street and track torture tested
- Black Anodized / Torque Solution Laser Engraved
- PTFE Lined FK Rod Ends
- Limited Lifetime Warranty
