Mark this thread as Unsold
Brembo GT 6 Piston Monobloc Calipers - NEW
Category: Brakes
Price (no $ sign please): $2250
Part fits (select ONLY those which apply): 911, 912, 914, 924/931/944/951/968, 928, 964, 986, 987, 993, 996, 997, Cayenne, Cayman, Carrera GT, Panamera, Race Car, Other Marques
Location (Region): SoCAl
Item Condition: Brand New
Calipers are yellow in color
Caliper part number 20.9733.01 and 20.9733.02
Brembo High Performance FM1000 brake pads
Brake Pad part number 07.9551.13
Original packaging
Weight of each Caliper with Pads is approximately 11.5lbs
Factory Brembo Information:
The Gran Turismo system’s level of technology and performance is unrivaled by any other product on the market. By utilizing larger calipers, thermal capacity and brake torque is increased. This offers the extreme in Brembo’s leading edge technology for high performance street or track use applications.
• Brembo 6 piston Monobloc calipers with sequentially sized pistons
• Brembo high performance brake pads
• Brembo “floating” anti-rattle disc hardware
• TÜV Certification
* Brembo brake systems are fully compatible with ABS and traction control system.
BREMBO HIGH PERFORMANCE BRAKE PADS
Each Brembo system is delivered with preloaded calipers. Brake pads are selected vehicle specific for high performance.
OPTIMUM BRAKE BALANCE
Brembo calipers are designed with differential piston bore sizes for even pad wear and OEM approved dust boots to protect the pressure seals & fluid.
HIGHLY PROTECTIVE PACKAGING
Only Brembo packages each of its components in fitted foam insulation to ensure that each system reaches you in perfect condition.
Price: $2250
Brackets available to fit 986, 987, 993c2, 996c2, 997c2 for an additional $350
The brackets are approximately 18.77mm tall. The brackets may require additional spacers to achieve the proper height for your rotors.
The brackets are an additional $350.
Again, these calipers can fit 355-405mm tall rotors and 32-34mm wide rotors.
Here are installation instructions, you can see the bracket height for the 355mm rotor:
http://www.pelicanparts.com/techarti...ke_Upgrade.htm
