Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
FS: 95 993 3.6L engine - 95K miles, fresh service
Old 05-05-2016, 08:08 PM
JJK78
JJK78's Avatar
Default FS: 95 993 3.6L Engine & Transmission - 95K miles, fresh service
Category: Engine - Complete
Price (no $ sign please): $16000
Part fits (select ONLY those which apply): 911, 964, 993
Location (Region): SouthEast
Item Condition: Used
For Sale:
1995 Porsche 3.6L Non-Varioram Engine & 6-Speed C2 transmission with 94,238 Miles
Engine: Complete from airbox to mufflers including ECU, Fuel Pump & wiring harness.
Transmission: 6-Speed C2 Manual transmission, NON-LSD shifts smoothly through all gears. *All other conversion parts are available as well.
Buy both for $16,000
Items are located in Marietta, GA.
Engine has no "check engine" lights and all EGR ports were inspected while exhaust was removed during service and found to be quite clean. PO just completed $3,587 Oil leak repair and 90K service. Had all oil leaks fixed including replacing valve cover gaskets, removing timing chain housings and replacing all associated gaskets, motor has NO leaks - just completed with documentation:
New Spark plugs, Complete ignition wire set, Distributor caps, Distributor rotors, Distributor belt, Power steering belt, A/C belt, alternator/fan belts.
Upper & Lower Valve Cover Gaskets
Timing Chain Housings & all associated gaskets and seals.
Motor and trans are still in the car but will be removed this weekend.
Video of a final startup:
Video of compression test:
Compression Test results:
Cylinder #1 190 PSI
Cylinder #2 187 PSI
Cylinder #3 190 PSI
Cylinder #4 191 PSI
Cylinder #5 182 PSI
Cylinder #6 185 PSI
Rare/odd/interesting trades considered. Would also accept pre-1964 US Silver coins, silver dollars etc.
JJK78 is offline
Old 05-17-2016, 07:39 PM
JJK78
JJK78's Avatar
Bump, price drop. $16,000 for motor and transmission, located in Marietta, GA.
JJK78 is offline
Old 05-18-2016, 12:02 AM
JJK78
JJK78's Avatar
Originally Posted by drb930
Any idea what shipping would $ to 91406?
Los Angeles... could provide a loading dock here...
Thanks,
Dave
Hello Dave,
Online shipping quotes from Uship.com show anywhere between $275-$750 depending on the carrier. I would prefer to ship it with a larger carrier like Fedex or Yellow Freight which is around $500 and would take 4-5 days to get there.
Thanks
John
Parting out the rest of the car too on eBay - http://www.ebay.com/sch/random816/m....p2047675.l2562
JJK78 is offline
Old 05-26-2016, 10:15 PM
redlinemotorsportsaz
redlinemotorsportsaz's Avatar
Sent PM.
redlinemotorsportsaz is offline
Old 05-27-2016, 06:34 PM
remsteve
2nd Gear
remsteve's Avatar
Do you sale tranny separately?tnx
remsteve is offline
Quick Reply: FS: 95 993 3.6L engine - 95K miles, fresh service
