Cobb access port for 997.2 turbo
Category: Accessories
Price (no $ sign please): $1100
Location (Region): NorCal
Item Condition: Used
Which programs are on the Cobb? Are you the original owner? I have a 2011 997.2 Turbo with a manual 6 speed and a Sharkwerks X-Pipe...is there a program for that on there? If I want to flash back to the original, can I do that?
It comes with stage one and stage 2. Tunes 91 octane
93 octane and 100 octane
it also has the stock program from your original file
And also a valet mode
your car would be stage two
And it installs very easily and also uninstalls very easily
Received 2,010 Likes
BTW, the $1100 is a great price. I bought a used on for my TTS and LOVE IT!! Works great. Yes, Stage 2 - 91 or 93 octane tune will work for you.
As per Cobb:
Box: If the used Accessport comes with a box, look at the box sticker. The part number should be displayed on the box sticker. If you see an AP3-APA-001 as a part number, you will have to look elsewhere (Accessport Screen or AP Manager) for the part number as this is a part number for a blank Accessport before it has been activated to work with a vehicle.
MikeRosi, what are the other numbers on the box (if you have the box) of your unit as per above (as your unit was originally blank)? If you do not have the box, what is the serial number under the faceplate? Also what is the "Installation State" of your unit (either "Install" or "Uninstall"), as per Cobb's link for buying a used unit?:
https://cobbtuning.atlassian.net/wik...sed+Accessport
As per Cobb:
I have the original box and the original receipt
do you want the serial numbers and
are you interested in purchasing
Thanks Mike 707-489-4031
