Mark this thread as Sold
Dealer Inventory 2007 Porsche 997 Turbo - Manual - PCCB - Modified
Former Vendor
Year: 2007
Make: Porsche
Model: 0
Cont. Porsche Models: 911
Mileage (numbers only please): 63000
Color: Black
VIN: WP0AD29937S783559
Price (no $ sign please): $71500
Private or Dealer Listing: Dealer Listing
Location (Region): NorCal
Body Style: Coupe
Engine Type: Fuel Injection
Stereo System: AM Radio
Build Sheet / Modifications
The VIN number for the car is WP0AD29937S783559 and I have attached a picture of the $144,533 MSRP build sheet. Some of the key options:
220 – Axel-Differential Lock Rear
342 – Heated Front Seats
450 – Ceramic Composite Brakes – PCCB
635 – Parking Assist System
640 – Sport Chrono Package Turbo
P01L – Adaptive Sport Seats
XCZ – Sport Shifter
XPA – Thicker Steering Wheel
The car also contains the following aftermarket modifications:
Hardwired Valentine V1 Radar in the rear mirror
Cobb Accessport with Stage 2 Tune
Sachs 2.5 Clutch
Speedtech Catless 3.0” X-pipe exhaust
H&R Springs
- Miles: 61,591 – Exhaust System Installed – Speedtech Catless 3.0 X-Pipe
o Exhaust system installed
o Replaced all gaskets
o Replaced exhaust studs and nuts
o Purchased and replaced all front and rear O2 sensors
- Miles: 62,000 – Oil Change
- Miles: 62,625 – New Battery – Bosch Platinum Series
- Miles: 62,745 – New Front & Rear Brake Pads, Sensors & Caliper Bolts
Former Vendor
- Miles: 59,958 - Major 60K Service
Customer requested major service
Per request, performed major service. Changed engine oil; oil filter; filter o-ring and crush washers
Removed and replaced engine air filter. Removed and replaced in-cabin pollen filter
Removed and replaced all spark plugs. Applied fuel additive and windshield washer solvent
Performed system diagnosis, read out any faults present in DME.
Inspected all under-body panels - ensure all are secured and tight. Passenger side front wheel liner damaged and spoiler was gone.
Inspected coolant level and antifreeze condition. Inspected radiators for blockage or external debris
Inspected brake hoses and lines. Inspected all drive shaft boots for leaks and wear. Checked out ok.
Inspected drive belt condition, serpentine belt need replacement. Serpentine belt replaced. Also removed and replaced fuel filter.
Checked all drains for debris and blockage. Checked out ok.
Checked all doors; lid locks and hood latches for proper function. Checked out ok.
Checked horn; vehicle electrical including turn signal and headlights functionality. Checked out ok.
Checked vehicle warning lights and battery condition. Checked out ok.
Found front brake pads at 6mm remaining and rear pads at 7mm remaining
Found front tires at 7/32" tread depth and rear tires at 5/32" tread depth
997 turbo
Hey guys. Interested in the black 2007 997 turbo. Couple of quick questions. Do you guys offer financing ? Or would I have To seek my own finance before purchase. Also I’m located in NY. Would shipping be an option or how do you guys go forward with sales as such / recommendations.
Thanks.
very interested, a call or text at 3475101490 would be great. Thank you.
Chris Em
Thanks.
Chris Em
