FS 1988 951 Turbo
6th Gear
FS 1988 951 Turbo
Year: 1988
Make: Porsche
Model: 0
Cont. Porsche Models: 944 Turbo
Mileage (numbers only please): 85000
Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows, Sunroof
Color: red
VIN: WP0AA295XJN150343
Price (no $ sign please): $19500
Location (Region): NorthEast
Body Style: Coupe
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Over $26k in repairs in the last two years.
Recent work performed :
7/6/2015 Miles 82004
Replaced brake booster with new OEM Flush brake fluid.
Replaced power steering hoses and rack. Replaced hood struts
Replaced fuel lines in engine compartment Replaced fuel damper.
Mount 2 Factory 17X7.5 Cup 4 wheels Mount 2 Factory 17X8.5 Cup 4 wheels
Four Conti Extreme contact tires 4 wheel alignment Replaced new OEM turbo charger. Clean intercooler.
Replaced radiator hoses and coolant Replaced steering rack and boots Replaced coolant tank and coolant
Replace oil sending switch. Replaced Timing belt and water pump Tensioners rollers v belt
Repl water pump and thermostat Replaced front and rear struts with Koni Sport inserts.
All front suspension bushings replaced. 4 Wheel alignment
9/1/16 - 12/1/16 Additional new items.
Bosch High volume fuel pump All temp sensors Crank sensors.
Focus 9 Tech Hybrid DME and solid state DME relay.
Lindsey racing MAF kit with Chip upgrade, cold air kit new by pass valve.
80 Lb injectors. New 3 bar Fuel pressure regulator.
( All old parts go with sale. Still functional. Just replaced due to age.)
Previous repairs Clutch 5/21/2009 58K miles AC converted to R 134 5/31/2013
Cyl head gasket valve guide seals resurface head.7/1/2014 Miles 75767
Paint has some road rash you would expect on a 29 year old car. Dash has the customary crack by the defroster vets.
Drivers seat has minor wear on the bolster. Radio has been replaced with aftermarket Kenwood.
Have a binder with service records back to 1993. Receipts for all work and parts available for inspection.
Inspection by your inspector welcomed. CARFAX has no issues.
In short, and excellent example. Drive and go. Needs no repairs. All the expensive stuff has been done.
Hard to find with the records of maintenance documented like this one.
"Mount 2 Factory 17X7.5 Cup 4 wheels Mount 2 Factory 17X8.5 Cup 4 wheels"
Well it is true that those wheels came out of a factory, but they are not factory OEM wheels. Those are quasi replica wheels made by sport edition:
https://www.tirerack.com/wheels/spor...ion-wheels.jsp
