1987 Porsche 911 Carrera 2dr Coupe 5-Spd
Year: 1987
Make: Porsche
Model: 911
Mileage (numbers only please): 144435
Color: White
VIN: WP0AB0910HS121993
Price (no $ sign please): $69959
Location (Region): SouthEast
Body Style: Coupe
Transmission Type: Manual - 4 speed
Engine Type: Fuel Injection
Stereo System: AM Radio
All service records, books & papers, including the original buyers order, owner's manual, stamped maintenance log, keys, air compressor, tool kit, original Blaupunkt. Complete engine rebuild approximately 8k miles ago with receipt for almost $11k in labor and $30k in parts. Car received some extensive upgrades and service in 2014 with compression at 5-6% of factory spec on each cylinder (as tested April 2016). Elephant Racing Full GT3 suspension. Von street front coilovers. Von double adjustable rear coilovers. Elephant Racing Single-Bar QuickChange front strut brace. Hollow front sway bar. QuickChange Camber Plates. OEM new Turbo tie rods. ASP adjustable spring plate. Elephant Racing rear hollow sway bar OVER $13K IN SUSPENSION PARTS ALONE. SSI heat exchangers. WEVO G50 shifter. WEVO SS transmission beam. WEVO semi-solid engine mounts. WEVO Carrera PSJ coupling. Dansk Sport Exhaust. Brembo GT 323mm Big Brake Kit (front). Brembo GT 309mm Big Brake Kit (rear). CCW LM5 forged wheels with Satin Black Centers 17x8 and 17x9 with new Michelin PS2s. Aligned, corner balanced, etc. AC system delete (all components, hoses and wiring removed). Optima battery & adapter plate. Approximately 3k miles since the above work was completed. Too many new parts to list and no expense spared. No rust. No damage. Car never tracked; only street driven. Always garage kept & covered.
