FS: 944 Garage Sale Suspension Components
FS: 944 Suspension Components PRICE REDUCED
Price (no $ sign please): $0
Part fits (select ONLY those which apply): 924/931/944/951/968
Location (Region): NorthEast
Item Condition: Used
Purchase the complete offered package for a 15% discount plus shipping for all items or 10% plus shipping for 3 item
Upgrade your track car or race car with slightly used Koni double adjustable front and rear shocks. Time on the shocks is approximately 15 track days and are in good condition. Reason for selling is moving up to the next level of racing where to be competitive, the shocks are nitrogen pressure that costs 7X the Koni’s sale price.
All prices are item cost plus shipping.
1. Front early reinforced steel lower control A arms with Racer’s Edge front bushing kit and standard ball joint. A arms are compatible with Tarett front sway bar or factory sway bar.
A Arms
The sale price is $219 or OBO plus shipping
2.. SOLDFront C/O Koni 8611 double adjustable shocks for early spindle, for late spindle insert 1 mm shim on each side of spindle flange and adjust eccentric camber bolt hole slightly. The lower adjustable spring perch is included. The 2 1/2" OD C/O spring set up is an 8 inch L main spring and a 4 inch helper/tender spring with interlocking collar
Koni Front Strut and Shock Assembly
Sale price is $599
3. SOLD Hyperco 2.50 OD, 400 lb/in, 8” L used once. Price for pair is $100.
Hyperco Front 2 1/2"OD, 8"L, 400 lb/in
4.SOLD Rear C/O Koni double adjustable shocks with all 2" OD spring perches and upper mount eyelet spacers. Spacers not shown but are included. Sale price is $499.
Last edited by T&T Racing; 09-26-2018 at 07:13 AM. Reason: Change pricing and sold items
Interested in the rears. Were you using them as helpers or full coilover with torsion bar delete?
Do you know what range of spring rates the valving is set for?
Porsche 944 Garage Sale
A Arms
The sale price is $219 OBO plus shipping
2.. SOLD Front C/O Koni 8611 double adjustable shocks for early spindle, for late spindle insert 1 mm shim on each side of spindle flange and adjust eccentric camber bolt hole slightly. The lower adjustable spring perch is included. The 2 1/2" OD C/O spring set up is an 8 inch L main spring and a 4 inch helper/tender spring with interlocking collar
Sale price is $599
A Arms
Sale price is $599
Sent you another PM, i'll take the rear Koni's.
Thanks!
Thanks!
Bump. Great deals for biggest bang for the buck front struts and early lower control arms with Racers Edge spherical bearing mounts, Make your track car turn in with more responsive and feedback and faster lap times
