FS: 986/987 Rear Tarett Monoball Shock Mount - Dome Style
Price (no $ sign please): $425
Part fits (select ONLY those which apply): 986, 987
Location (Region): Midwestern
Item Condition: Used
Selling for $425 free shipping included can be picked up locally zip code 60565. Shipping within USA only.
PM please.
Rear TARET ENGINEERING Monoball Shock Mount - Dome Style - $595 new, will take $425.
The compliant factory rubber bushing is replaced with a precision Teflon-lined spherical bearing for quicker steering and shock response, and increased suspension precision resulting in better handling. The spherical bearing is made to our specific specifications, and will not wear out and rattle like others on the market. The housing is CNC machined from 6061-T6 aluminum billet, providing high strength, light weight, and a perfect match to the factory mounting surface. The spherical bearing is securely clamped into the billet housing. Other designs use a small retainer ring to trap the bearing in a bore, which tend to cause annoying rattling and possible failure. The domed style is designed to replace the OEM mount and is compatible with any strut designed for use with the OEM mount. This would include Bilstein and KW among others. The spring load is distributed on the housing, not the monoball, for increased monoball life. These are the only upper mounts on the market that are fully compatible with all factory and aftermarket style upper spring seats.
- Precision monoball bearing, positively clamped in position.
- CNC machined housing.
- No bearing noise.
- Spring load distributed on housing
- Fully compatible with factory and aftermarket spring seats.
