Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
GT3 996 mkII wheels
Old 09-12-2018, 05:56 PM
cgfen
cgfen's Avatar
Category: Wheels & Tires
Price (no $ sign please): $1500
Part fits (select ONLY those which apply): 911, 924/931/944/951/968, 928, 964, 986, 987, 993, 996, 997, Cayman, Race Car
Location (Region): Midwestern
Item Condition: Used
You might get better "eyeball" response if you change the thread title to indicate [GT3 "style" wheels for widebody cars], or something similar since your rear wheel offset does not work with GT3 chassis.
GLWTS
cgfen is offline
Old 09-19-2018, 09:20 AM
RangerRick
RangerRick's Avatar
Are these still available?
RangerRick is offline
Old 09-21-2018, 06:16 AM
Alpineace
Alpineace's Avatar
yes I still have them.
PM me.
Alpineace is offline
Old 09-22-2018, 03:26 PM
Cogito_Ergo_Zoom
Cogito_Ergo_Zoom's Avatar
Actually what these are a mix of GT3 Mk1 and Mk2 wheels. The fronts are from a Mk1 and the rears are from the Mk 2.
996 GT3 wheels came in the following sizes:
1- 8" x 18" - ET50 - Fits the front of any 996
2- 8.5" x 18" - ET40 - Fits the front of any 996
3- 11" x 18" - ET 45 - Fits the rear of a widebody 996
4- 11" x 18" - ET63 - Fits the rear of any 996 and widebody 996 w/spacer
5- 12" x 18" - ET45 - Fits on the rear of 996 GT2 only
Standard wheels for a 2004 GT3 are:
Front: 8.5J X 18 offset 40 mm
Rear: 11J X 18 offset 63 mm
996 Cup:
the cup cars use 9j and 11j x 18 and their offsets are 46.5 and 59 respectively
Cogito_Ergo_Zoom is offline
Old 09-26-2018, 04:50 PM
jcrane968
jcrane968's Avatar
do these match this specs?
996 Cup:
jcrane968 is offline
Old 09-26-2018, 05:45 PM
Cogito_Ergo_Zoom
No, they don't. As I stated in the previous post, these appear to be a "mix" of GT3 wheels from the first and second gen. The fronts are 8J x 18 ET50 from the front of a narrow body 996 GT3 and the rears are 11J x 18 ET 45 from the rear of a widebody 996 GT3.
The fronts should fit any 996 but the rears would only fit the narrow body car with some accommodation.
Old 09-27-2018, 09:03 PM
Alpineace
Alpineace's Avatar
once again, to clarify. These fit widebody, ie Turbo/c4 (which is what they were on)
they also fit boxtster/cayman.
Im going to post another ad with a little more clarification.
Old 10-02-2018, 02:48 AM
Projekt EPiK
Projekt EPiK's Avatar
Just wanted to mention, I have successfully used wheels with this same spec (solid C4S 18x8/11 twists) on my 1999 Carrera 2 which is a narrow body. My car also has H&R Sport springs and I experience no rubbing. The rear wheels sit flush to the fender lip.
GLWS
Projekt EPiK is offline
Old 10-03-2018, 02:03 PM
orangeman
orangeman's Avatar
GLWS
Sold twists on C4S had a 63 offset, not a 45 et. Looking at mine right now. So not the same as these, though I suspect they would fit an NB car anyways.
orangeman is offline
Old 10-03-2018, 02:04 PM
orangeman
orangeman's Avatar
These rears will absolutely not fit a boxster 986. I doubt they would fit an 987 either.
Old 10-04-2018, 10:20 AM
  #26
Projekt EPiK
Semantics.. the rear wheels pictured on my 1999 c2 are 18x11 et45. Same spec as what he's selling, different wheel, but apples to apples.
Old 10-05-2018, 04:59 PM
  #27
techweenie
techweenie's Avatar
Here's a simple test: if you are able to successfully add 18mm spacers on 63mm offset wheels, with proper clearance in all driving situations, you should be able to eliminate the spacers and directly bolt on 45mm offset wheels of the same width.
In reality, not all of our (99X and 98X) cars have that much wheelwell clearance.
techweenie is offline
Old 10-05-2018, 07:28 PM
  #28
manimal
manimal's Avatar
Sounds like you have NB twists -- C4S solid spokes should have a 45 ET just like Turbo hollows.
On the widebody cars, Sport Technos (also a 63 offset) came from the factory with 17mm spacers.
manimal is offline
Old 10-05-2018, 07:44 PM
  #29
Projekt EPiK
My solid widebody twists. 18x11 et45 were on my 1999 Carrera 2 NB with no issues.
Old 10-12-2018, 05:35 PM
  #30
Alpineace
Alpineace's Avatar
thanks for the info.
Still available
Quick Reply: GT3 996 mkII wheels
