Mark this thread as Sold
Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
PCCB Brakes for 991 GT3/GT3RS - comes with pads and rotors
Old 04-11-2019, 05:46 PM
titannero
Basic Sponsor
titannero's Avatar
Default PCCB Brakes for 991 GT3/GT3RS - comes with pads and rotors
Category: Brakes
Price (no $ sign please): $7999
Private or Vendor Listing: Vendor Listing
Part fits (select ONLY those which apply): 911
Location (Region): SouthEast
Item Condition: Used
5k miles, great condition complete car set of PCCB Rotors and Pads. Within spec and can ship worldwide. Perfect setup if your swapping from Steel Rotors to PCCB's
Can ship worldwide
titannero is offline
Old 04-11-2019, 07:23 PM
nolimits
nolimits's Avatar
What were the rotor specs and were measurements done with them on or off the car. Roughly how many track miles?
nolimits is offline
Old 04-12-2019, 11:50 AM
titannero
Basic Sponsor
titannero's Avatar
Pictures are before removal, measurements taken after removal
Front Rotor specs
Minimum Weight 6641 Grams
Currently 6720 Grams
Currently 36mm
Pad life 65%
Rear Rotor specs
Minimum weight 6042 Grams
Currently 6100 Grams
32mm thick
Pad life 75%
Old 04-12-2019, 01:56 PM
nxfedlt1
nxfedlt1's Avatar
calipers between steel and pccb are not the same fyi. the tabs are different heights which is what accomodates the different disc sizes.
nxfedlt1 is offline
Old 04-12-2019, 02:10 PM
titannero
Basic Sponsor
titannero's Avatar
Correct which is why you would space the caliper up for the larger rotor. They use the same pads.
Old 04-13-2019, 12:14 AM
the_vetman
the_vetman's Avatar
OK, so now that's been brought up I can ask this: what's involved in going from PCCB to iron/steel? Spacers? Or take spacers out?
Obviously iron rotors, pads, and calipers.
the_vetman is offline
Old 04-15-2019, 03:49 PM
titannero
Basic Sponsor
titannero's Avatar
PCCB to Iron Steel its best to do the GIrodisc conversion as the rotor size is larger then the standard steel brakes. You can't easily use the standard steel brakes as the caliper spacing is off and your pad contact area will be less then ideal.
For Steel to PCCB, you just need to space the calipers higher, change the pad and the rotors to PCCB and you can go.
Old 04-15-2019, 04:16 PM
oreganoflow
oreganoflow's Avatar
i did the steel to ceramic swap on an f80 m3 and the brake booster had to be swapped (380mm to 405mm). there was also coding for the brake booster.
don't know if its the same here...
oreganoflow is offline
Old 04-15-2019, 05:45 PM
titannero
Basic Sponsor
titannero's Avatar
Nope, just spacer and longer brake line from Porsche for the swap. Otherwise its a straight on affair
Old 04-23-2019, 05:26 PM
titannero
Basic Sponsor
titannero's Avatar
Quick Reply: PCCB Brakes for 991 GT3/GT3RS - comes with pads and rotors
