Mark this thread as Unsold
Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
WTB: 997.2 GT3/RS Front Wheel Carriers/Uprights for PCCB Brakes
Old 06-27-2018, 03:57 PM
danco_
danco_'s Avatar
Default WTB: 997.2 GT3/RS Front Wheel Carriers/Uprights for PCCB Brakes
Category: Steering & Suspension
Price (no $ sign please): $1
Part fits (select ONLY those which apply): 997
Location (Region): SoCAl
Item Condition: Used
Hi guys,
Looking to purchase a set of front wheel carriers from a 997.2 GT3 or GT3RS. These uprights/wheel carriers must be from a PCCB-equipped vehicle, as the caliper bolt spacing is different on PCCB uprights.
I'm a motivated buyer and happy to do this deal immediately.
Please DM if you have something that fits the bill. If you leave your phone number, I can call you. Cheers!
Thank you,
Ryan Danco
danco_ is offline
Old 06-27-2018, 06:05 PM
RacingBrake
Former Vendor
RacingBrake's Avatar
Non-pccb 997 has a caliper mounting spread of 142mm, while pccb 997.2 GT3 is 225mm (same as 993 GT3)
Other than mounting spread, the offset and mounting height are different. Not sure what you intended to accomplish, but if the swap is to facilitate the pccb calipers install, then an adaptor can convert your upright from 142 to 225mm including to accommodate the rotor diameter/offset change, so you can transform your 997 upright to GT3 without all the hassles and expenses.
We know Porsche brakes in-side-out, so let's know if anything we can help.
714-871-6392
RacingBrake is offline
Old 06-28-2018, 11:08 AM
Johnny DB
Johnny DB's Avatar
Can you make an adapter to run 410mm rotors on a 997 Turbo equipped PCCB car?
Johnny DB is offline
Old 06-28-2018, 11:24 AM
RacingBrake
Former Vendor
Subject to the caliper you have in mind which dictate the rotor size and offset, and adaptor design.
Warren-RacingBrake
Old 06-28-2018, 11:42 AM
Johnny DB
Johnny DB's Avatar
I want to run the OEM 410mm Porsche Turbo PCCB using my current 997 PCCB yellow calipers.
Old 06-28-2018, 01:02 PM
RacingBrake
Former Vendor
Most likely it will not work. 993 pccb rotor is a 410x36 which 997 pccb calipers will NOT fit.
Shouldn't it make more sense to have a larger CCM rotor (although may not be as large as 410mm) that can fit right under the original 997 pccb calipers. Please identify your calipers here.
https://www.racingbrake.com/category-s/7500.htm
With this alternative, you don't have to change anything, upright, caliper, pad etc. remains as stock, only larger CCM rotors and spacers.
RacingBrake knows Porsche brakes, and we make your brake upgrade simple and cost effective, and we are the only brake company that has the knowledge and resource to make custom size CCM rotors (in this case). Right at very first time with quick turn around time.
Quick Reply: WTB: 997.2 GT3/RS Front Wheel Carriers/Uprights for PCCB Brakes
