Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
Complete custom Ohlins package for Caymans
Old 11-20-2016, 10:33 PM
sl951
sl951's Avatar
Default Custom Ohlins Shocks Struts package for Cayman
Category: Accessories
Price (no $ sign please): $5250
Part fits (select ONLY those which apply): 987
Location (Region): NorCal
Item Condition: Used
For Sale: A complete custom Ohlin’s shock suspension package for a 2006-2012 Cayman – the very best available.
Package includes:
4 – Custom PSi/Ohlins 36HMRC double-adjustable inverted struts with external reservoirs.
2 – Elephant racing camber plates
2 – Rear OEM strut bushing plates
2- Tarret racing rear coil adapter plates
2 – Eibach 225lb 8” springs (0800.225.225)
2- Eibach 350lb 8” springs (0800.225.350)
2 – Eibach tender springs
2- Custom Front Remote Reservoir mounting plates
2- Custom front OEM threaded spring perches
2- Custom rear OEM threaded spring perches
2 – Cayman S (PASM) front springs
2 – Cayman S (PASM) rear springs
Unique and frankly awesome features:
- These shocks have a huge range of adjustability (20 clicks) on both compression and rebound (shock dyno graphs included) – so they work vastly better than OEM; for street use or can be quickly adjusted for national level competition (easy **** adjustment - no tools need). These are truly the best dual purpose shocks I’ve worked with. When dyno tested the range has shown to be broader than JRZ Pro’s (graph included)
- Flexibility to use both race springs (Eibach 2.25 inch) or OEM Porsche springs. Included are custom-collar threaded OEM spring perches. So if you’re looking add a 2-way adjustable shocks to your stock system, this is it. You can use your OEM camber plates and springs to be ‘rules’ compliant with SCCA street classes at national level competition.
- All 4 shocks have multiple levels of ‘height’ adjustability options. You can adjust the spring perches or adjust the length of the shock body that’s inserted into the wheel carrier. This allows you to optimize the working length of the piston
- Huge 40mm working diameter inverted strut for maximum MacPherson strut stiffness
- Gain up to -3.0 degrees front and rear camber without the need for ‘GT3 arm’ swaps. I was able to achieve these numbers with the include camber plates
- Custom Remote reservoirs holders were designed to fit neatly under the stock plastic trim pieces (installation pics will be included) - an OEM fit and finish.
This package has less than 8K miles on them. Recently inspected by Performance Shock, inc (PSi), there are no leaks or rebuilds need in the near future.
I can’t say enough about the quality - Ohlins is the best!
This very package helped me win several national titles in both PCA and SCCA clubs.
sl951 is offline
Old 11-28-2016, 01:58 AM
sl951
sl951's Avatar
sl951 is offline
Old 02-22-2017, 01:59 AM
sl951
sl951's Avatar
sl951 is offline
Old 04-07-2017, 02:10 AM
sl951
sl951's Avatar
still available
sl951 is offline
Old 09-25-2017, 12:57 AM
sl951
sl951's Avatar
still available
sl951 is offline
Old 09-25-2017, 02:51 PM
Vince-
Vince-'s Avatar
How do you take the springs off with the hose over the top, the thread doesn't look like it goes all the way down?
Vince- is offline
Old 02-21-2018, 02:34 AM
sl951
sl951's Avatar
These are still available -
You can remove the lower bolt to remove the shock body for spring changes.
sl951 is offline
Quick Reply: Complete custom Ohlins package for Caymans
