2002 Boxster S
2002 Boxster S
Year: 2002
Make: Porsche
Model: Boxster
Cont. Porsche Models: Boxster S
Mileage (numbers only please): 125000
Options (Please check ALL which apply): Airbags, Air Conditioning, Alarm System, Antilock Brakes, Cruise Control, Intermittent Wipers, Leather Seats, Power Brakes, Power Door Locks, Power Steering, Power Windows
Color: Silver
VIN: WP0CB298X2U663633
Price (no $ sign please): $7500
Location (Region): NorCal
Body Style: Cabriolet
Engine Type: Fuel Injection
Stereo System: AM-FM CD
Anyway, I acquired the vehicle with 119,000 miles and it now has 125,000. This is my second Boxster. I bought this car mainly because of its service history. The car originated in AZ, made its way to OR/WA in 2005 and to CA in 2014. I am the 5th owner, and the 2nd in CA. The original top is still on the car. The plastic rear window is still very clear. In the time that I've had the car, I've repaired the LCD climate control display, fixed the on-board computer stalk, completed the set of wind deflector/wind screen and an oil filter/oil change. As you can see from the following service history, a lot of money was spent on this car.
Service history:
Drive belt 6/16/2011 @96,000
Water pump 6/16/2011 @96,000
AOS replaced 6/17/2011 @96,000
Spark plugs/spark plug tubes 7/9/2011 @96,700
Engine air filter 9/1/2011 @99,369
Coolant flush (Porsche coolant) 10/25/2011 @100,101
Transmission fluid changed 3/20/2012 @101,225
New battery 4/22/2012 @101,438
Right axle CV boots replaced (both) 2/18/2013 @103,761
Brake fluid flush 2/19/2013 @103,774
Cabin air filter 5/4/2013 @104,237
Secondary air system vacuum reservoir replaced 5/13/2013 @104,291
O2 sensor replaced (bank 2) 5/13/2013 @104,291
New starter 5/13/2013 @104,291
New clutch/clutch arm 6/25/2014 @106,557
New flywheel 6/25/2014 @106,557
IMS retrofit (LN double row) 6/25/2014 @106,557
New alternator 2/26/2015 @109,607
New battery 2/26/2015 @109,607
Drive belt 2/15/2016 @112,226
Engine air filter/cabin air filter 2/15/2016 @112,226
Cabin air filter 7/19/2017 @113,578
New Bilsteins all around 7/19/2016 @113,578
New Michelin PS2 all around 7/19/2016 @113,578
Trans axle oil replaced 7/19/2016 @113,578 Noticed a slight tranny fluid leak from the shifter shaft seal with the long lever, recommendation from Modderman of Mountain View to monitor
Wheel alignment 7/19/2016 @113,588
AOS replaced 9/13/2017 @118,064
Motor mounts replaced 9/27/2017 @118,152
O2 sensors replaced (bank one fore/aft) 12/11/2017 @118,781
Heater core replaced 12/11/2017 @118,781
Left front wheel bearing replaced 12/11/2017 @118,781
Options codes:
C02: Catalytic converter
XWC: Porsche crest emobossed in headrests
446: Wheel caps with colored Porsche crest
454: Automatic speed control
502: Produced at Valmet plant in Uusikaupunki, Finland
551: Wind deflector
659: On-board computer
680: MY2002 Bose sound system
692: 6-disc CD changer Becker Porsche CDS-3
Needs:
A small tear in the driver's seat
Slight separation of the seat bottom of driver's seat
Only one keyfob
Keyfob does not open rear trunk but works for door and front trunk
Xerox copy of owner's manual
Monitor of small tranny leak as noted from Modderman Service of Mountain View
Some rock chips on front bumper and hood
Scrapes on lower half of front bumper
I also have a gray hardtop that I will be offering to the buyer for $1500 should he/she be interested.
sent PM
Is the hard top Seal Gray or Arctic Silver? Can you post photos of that?
Matt
Matt
