Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
KW Clubsport Coilovers - 987 - New Rebuild
Old 02-07-2019, 03:53 PM
Difool
Difool's Avatar
Price (no $ sign please): $2400
Part fits (select ONLY those which apply): 987, Cayman, Race Car
Location (Region): NorthEast
Item Condition: Used
The KW Coilovers are still available. I'm in the Boston area.
Difool is offline
Old 02-14-2019, 11:16 AM
Difool
Difool's Avatar
Bumping up from page 5 with a price reduction.
Difool is offline
Old 02-14-2019, 07:14 PM
JayL
JayL's Avatar
Default Kw clubsports
This is a bit of a long shot, but do you know how well the valving in these would be for a street car (using the softer springs)? I've had a v3 setup in the past but no experience with these and this isn't a track car. Anything you might be able to share would be appreciated and also help me make a decision.
thanks,
jason
JayL is offline
Old 02-14-2019, 07:47 PM
kisik
kisik's Avatar
Bump for great seller. Buy with confidence.
kisik is offline
Old 02-14-2019, 09:59 PM
Difool
Difool's Avatar
thanks,
jason
That’s a hard thing to comment on because when it comes to modifying suspension for the street it is just so damn subjective. These are a capable track parts, and are like 4xstiffer than stock. If you liked the Varient 3s then I suspect you will like the Clubsports as well. I believe They are designed for street/track mixed use. They have side-canisters for a bit more gas volume, and should react more predictably. You can use the stock springs, relax the compression damping to like 1/4, and set rebound damping closer to mid. I don’t think anyone would say the car is too soft, but it will let you ride lower and the car will drive very nicely. If it’s not tolerable I guess you wouldn’t take a depreciation if you resold them, as I’m already doing that! You could also pick up softer springs either from KW directly, or swift, or eibach. They are standard diameter springs. You could go down 100# on each corner and still be matched well with the dampers, just like I did, but in the other direction.
hope that helps. If you can find someone else that has done this that might be good info. You can also call a shop that sells these, or write KW to get options on your application as well.
Difool is offline
Old 02-17-2019, 09:26 PM
Difool
Difool's Avatar
Sold.
Difool is offline
Quick Reply: KW Clubsport Coilovers - 987 - New Rebuild
