Homemade lift...Re-Tooling!!!
Erik, that's what I worry about most with plain stands (slipping off the tiny top). The first set of stands I ever bought long ago had a long, wide, flat top and a 3 point base much like the ones in the link you quoted. Personally, I like the 3 point base. If used properly, (as they are in the photo at the bottom of that site you quoted) there is a point inside or outside that has to be pushed against if the force is side-to-side. This is due to the angles (120 & 240 degrees) being different from the car's rolling angles (0 & 90 degrees). That leaves you with only 1 vulnerability at 360 degrees. With 4 point bases, the angles match and make it easier to roll, plus with points contacting the floor, it's more difficult to keep all points contacting the ground (concrete is never completely level).
New Question:
My personal preference would be to have it lifted by the tires (i.e. high ramp or cradle) with the base being 2' wide for stability. Basically, I'd like the base to wider and harder to move, but higher than the ramp on jorg's site (maybe a variation of that). I think this could be done with the steel 2x4s discussed before, but does anyone know how much weight an average 2x4 piece of hollow steel would hold at the center point if it were ~2' in length? If so, what's the strength at both placements (i.e. if it's placed horizontally on the 2" side and also on the 4" side).
What about pins that go through the steel and have a coter on the other side to keep them from sliding out. Anyone know how they affect the strength since a hole is drilled through the beam? What about the pin's strength itself, what size pin would be strong enough? By using 4 pins I think something could be constructed at a low cost and still be disassembled for easy storage.
Please post pics & ~cost for the fabrication. If you have measurements of the top part you had fabricated that would be great too.
When i did my TT many years a go i used solid wood that they use for the main beam above garage doors. I found mine in the scrap piles at local constructions sites. I cut them to 12" lengths then stacked and placed them under the wheels/ or the jack points.
In that design illustrated i would also put locater bolts in the wood so the bolts would drop into the holes on the jack points. It would help prevent the car from sliding of the blocks at that point.
Anyway, with the car up on stands, I've got 15 to 21 inches of clearance (probably more if I need it) and I worry a lot less about the car slipping. I do use a floor jack as an safety, just in case.
The floorjacks themselves are "GoodYear Racing" 6-ton units, with a safety pin to lock the upright into place, along with the ratchet action. The base is about 10" square or so. Got them from Sam's Club, really inexpensive, like about $25 for a pair.
I like the concept. It seems like a PIA to jack and to place jackstands to get the car fully up using usual means. Ideally we would all have 5-car garages - one bay having a hydraulic lift.
Given space concerns (and reality in general), isn't this design heading in the right direction?
I thought of that actually, but I have noticed that not all jackstands have the same saddle size, which becomes a problem. Let's see, I could make custom jackstands, with jackpad adapters......
Let me check with the legal department on the product liability aspects of that one...
With your photo I don't see an issue having them made up locally.
I've seen some adapters in one of the catalogs I get for the Boxster that fits on the round top of some floor jacks, but not jack stands.James...now that would be a garage!
I think I'm going to try Bill Sanders' jack stand pads with dr. bob's suggested larger, wider based stands and pads under the stands at 1'x1x and 1'-6"x1'-6" for the additional height.
I think the setup I have is pretty stable, but would be more stable as dr. bob suggested with the additional lifting on bottom. I'll post pics of that once it's done for everyone's comments on stability before I get under it.
Thanks for all the good stuff!!!
How about a square steel 2x4 the length between the jacking points
At each end, one of the jack points that fit into our chassis welded to the 2x4
Is that about 5 feet? So at 1/4 thickness that would be about 45lbs per side
Would that be strong enought to jack the car up in the middle of the steel 2x4 or would it flex too much, hitting the undercarriage?
If a wood 2x4 is strong enought between the car and the jack stand, I'm sure a steel 2x4 would be safer, correct?
Weight of Square Steel
Tubing Size Wall Thickness Weight per Foot
2X3 3/16 5.59
2X3 1/4 7.11
2X4 3/16 6.87
2X4 1/4 8.81
2X4 5/16 10.58
With the tubing sizes you have listed at the end, I'd think the 2x3 would be stronger vertically (assuming you're talking about the beams laying on the 3" or 4" side) since there is less distance from the sides. As you said, it should be much stronger than a 2x4 piece of wood.
If you use the 2x3 or 2x4 as you suggest in order to have a single jacking point, what would the final setup rest on? If it's jack stands, what about "taking apart" Bill Sanders' jack stand cap. You talked about welding a jacking point to the top (the top half of Bill's piece) so what about having the bottom piece that wraps around the top of the jack stand welded to the bottom of that beam underneath the jacking point? That should make it very stable side-to-side.
Anybody know the strength of the different thicknesses HP has listed above at different lengths?
1/4 thick steel 2x4 is $12 per foot = $144 in steel.
Maybe even rig up something where the U bracket on the bottom and the nipple going into the car is a solid piece that slides over the 2x4. That way I could also use this for my 944.
I was thinking about the 4" part resting in the jack stand, seams sturdier that way. Welding the U shaped bracket on the bottom is a great idea.
I plan on having a jack stand under each factory jacking point. The only purpose of having the 2x4 stretch the length of the car is to raise the car up once per side to place the jack stands.
For strength, you wouldnt have to jack the car up in the middle, maybe 6" away from the jack point, leaving enough room for the jack stand to slide under. Go high enough and you could squeeze both stand under the car that way.
This still doesnt fix the possible issue of tipping the jack stand over. My whole purpose for this idea is to jack the car up once per side and have a solid base between the car and jack stand.
One other thing I believe would help even more with tipping would be to weld the U-shaped holder at a 30 degree angle. If the stand is angled a little, it would give a wider area going against the 90 degree angle the car would most likely push at. Just thinking outloud on this part so please chime in if you know anything about that theory.
