Does anyone know who makes this wing.
Check this black car with wing that still works with the OEM wing.
https://rennlist.com/forums/996-foru...lub-today.html
Who makes this ?
Who makes this ?
Msg the guy and see if he can find any markings.
I've looked and didn't see any markings at all so far. I plan to meet with the P.O. soon, and will be sure to ask if she knows anything about it or if there is anything in the service folder I'm picking up.
Received 1,919 Likes
I know this OEM wing is crazy expensive, but I always thought it looked perfect on the cabriolets.
https://www.suncoastparts.com/product/996REARW.html
I have a 1999 Cab with that wing on it. While it does look good, It does not force cool air into the intake or engine compartment as well as the standard dynamic spoiler. I have a 1999 Coupe that I compare it with since I have done some custom intakes and heat shields and compaired temps with various intakes, heat shields, wings, ect. But it does look good so it will stay..lol
Well yea that's one of the things the dynamic spoiler does.
1 . reduces lift on the rear for high speed stability
2. reduces drag for higher speed
3. increases fuel efficiency
4. forces ambient air into engine compartment to promote cooling
5. forces air into engine for combustion
I think it's because you used the word "force" which can be confused with super/turbo charging. If anything, some of the fancy Porsche wings do redirect air into the snorkel. (I've seen some that have side vents to capture air and push in the engine compartment) If you look at the belly of a Porsche's rear air vent, the snorkel port is the only way air is inputing; that is, for the throttle body. The other port is for the purge fan. Of course, I'm there are many who have removed these items to promote more air flow.
Personally, some of these non-tested, aftermarket spoilers can work against the normal flow of low pressure air and therefore, redirect air away from the vent, which could be counterproductive to performance. But I'm not sure any of the spoilers are going to promote better engine cooling. That's the job of the front radiators, heat diffusers, and purge fan.
Who makes this ?
Who makes this ?
Porsche states and my tests confirm that the factory spoiler "up" does improve engine compartment cooling and air intake air cooling via ambient air pressure increase.
That particular fixed spoiler runs the intake temperature about 10 degrees higher than the factory spoiler in the "up" position, and takes a lot longer to cool off after a hot soak.
Shameful Thread Killer
boyles law: PV=NRT where P is pressure and T is temperature, all other things being equal, to maintain the equation, as pressure rises if Volume, Molecular constant remain the same, then temperature will rise.
Also, 'via ambient' is logically inconsistent. Ambient is a relationship to something that is nearby. So, if you are comparing the inducted air to the engine bay, you would use ambient as a comparitor to the air which is not being inducted into the engine bay.
e.g. "The air inducted to the engine as a result of the wing is at a lower/higher temperature than the ambient air which is not inducted into the engine bay in a car without the wing."
again - sorry, but something else is at work there.
Doc, if I pour a bag of ice into my Porsche's snorkel, will the air going into the throttle body be cooler regardless of air pressure? A poor man's cold air intake?
Ok, scratch that... it will melt and that could mean excess water in my airbox which could lead to ... oh my... lead to... eeekk... HYDROLOCK!!!!
I apologize in advance for being a noodge, but improving cooling of the intake air by increasing the air pressure is incorrect. I don't know the aerodynamics of the situation, but in all cases(on planet earth) increasing the air pressure will increase the air temperature through adiabatic heating effect.
There was an old saying that I have used many times in the old days of HotRodding cars and the quest for eventually setting a couple IHRA World Records by doing things that had never been before," If the results differ from the theory, believe the results and invent a new theory".
From the Porsche P-001
Also from Porsche P-001 There are more references of this function that spells these benefits out more clearly, if I can find them in my heap of technical info.
