What I hate about my 2017 Cayenne
It's a CARB/EPA "feature". They don't want there to be an option at all and know (across all brands) that people were just disabling it. So now they are pressuring the MFGs to make it so that option resets at every start.
Doubt it will be much longer before there isn't a button for it at all
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Yeah I know I can do it in my 2013. I'm guessing that was something that changed with the .2 as well and the "typo" is that it was never removed from the manual.
I've yet to find a sat radio setup that I genuinely liked using. All of them suck one way or the other. I'm not defending Porsche setup, but it's 'just as bad' as a lot of others I've had to use. The PCM in my '17 does at least offer ways to scroll through current artist playing. Makes for an interesting way to see what's playing across a number of channels. That and there's some filtering. But it's still more tedious to use than I'd like. Especially without on-wheel directional control.
Doubt it will be much longer before there isn't a button for it at all![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Meanwhile the T-Design folks are going to use my 958 as a guinea pig this weekend for a memory module to overcome this.
![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
I came up with the 4th thing I hate about the 2017 Cayenne - the lack of a solid sunshade for the panorama sunroof. Other manufacturers have a solid cover that doesn't bleed light through. I wonder why Porsche doesn't have this. I also can't find an aftermarket solution
I've wondered why it has slight perforations but haven't found it a problem. it doesn't pass enough light to be an issue.
Having a shop apply a 20% tint really helps. I did that to my CTS-V and never needed to pull the sunroof shade. Planning on doing it to the Cayenne as well here someday.
If you really want to kill the light, put on a 5% tint...
The ultimate solution to all these foibles on the Cayenne is:
A nice, new Toyota Highlander or Honda Pilot, then the sunroof shade letting in too much light, the radio controls not working from the steering wheel, and the Stop-Start would not be an issue at all as those manufacturers know how to make their vehicles work the right way, not like the Cayenne.
The CR-V or the Rav4 are other, solid choices. Too bad Subaru doesn't make a competing SUV. They would absolutely blow it out of the water if they ever did.
You can tint the sunroof and it becomes much more usable.
Tangentially, I got one of these:
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/500x164/s_l500_1__c52e7958ecc78dd5dbe9ec6af4e28af56c7583a6.jpg)
I've posted about it here:
https://rennlist.com/forums/cayenne-...ss-holder.html
Heh, I hear ya.
I spent two months last summer doing test drives and taking overnight loaners of just about every mid/up-market SUV. All had their merits but the best value all-around was probably the Acura MDX. Everything came together pretty well and for a reasonable amount of money. Engine/nav/infotainment/handling were all quite nicely done. Had I been limited to a sane amount of money I'd have given it serious consideration. And hated making the compromise.
But none of them came anywhere close to how well a Porsche handles. I'm sure competent drivers can wring all kinds of performance out of anything. But right off the lot the Cayenne just drives better, both at how I like to drive it... and also at reasonable/legal speeds. I just didn't get that in anything else on the market at the time. Even my wife commented during a drive out for dinner tonight, "other cars just don't drive as well as these, do they?"
So, yeah, Porsche's way of mis-managing infotainment and other 'features' pales in comparison to just about all the others. But then I didn't spend this amount of money for that.
That's interesting because in my 2013 CD I can scroll through the SAT presets. Not sure if it is all of them, I don't think so, but there are at least 10 of my preset channels I scroll and press the button to switch to. I definitely do not see the 100+ channels and the ones I do see are the ones I purposefully set. Maybe it was an older version feature no longer supported in the newer PCM/MFD.
I also have a 2016 Cayenne and I'm quite sure that you can do this. I believe you have to select another option once you are in the audio menu to scroll through your presets.
