996 Forum 1999-2005
Earliest production dates
Old 05-06-2017, 09:20 AM
  #46
longrowe
longrowe's Avatar
Not just NA cars. Mine is GCC (Middle East) spec and my plate is in the passenger door sill.
Originally Posted by Volkert
I guess these stickers are only in NA cars?
All I could find was this in the engine department:
It has a manufacuring date of October 8, 1997. I guess this relates to the spoiler mechanism? But I don't know how that relates to the car's manufacturing date.
Old 05-06-2017, 10:53 PM
  #47
Splitting Atoms
Splitting Atoms's Avatar
Parts are often manufactured months before the car.
I am curious about the VIN number compared to the build date. You would think it is car number 2301 (starting with 00001) manufactured and that there were 2300 cars built before it, but that seems unlikely to me with a 12/97 build date.
Last edited by Splitting Atoms; 05-07-2017 at 12:01 AM. Reason: Revised numbering. This car is SN 02301
Old 05-06-2017, 11:48 PM
  #48
longrowe
longrowe's Avatar
Interesting question. How many cars roll off the line in a month? If the 996 started production in Aug/Sep of 1997, how likely is it that they would be at 2300 by December?
Old 05-07-2017, 01:39 AM
  #49
longrowe
longrowe's Avatar
This paragraph is from Porsche 911- 50 years
Old 05-07-2017, 03:05 AM
  #50
Volkert
Volkert's Avatar
I earlier assumed my "0992" would have been build around October/November. They only build coupes initially, so 500 cars per month, starting August? That could approximately work. Then adding cabs per February or so, leading to 10.000 cars manufactured in total for MY98?
Do cabs and coupes share their VIN number?
Volkert
Old 05-08-2017, 09:46 AM
  #51
Jimt565
Jimt565's Avatar
Mine is a MY99 C2 Cab. 2/98 but look at the serial number 0089?
Old 05-08-2017, 04:03 PM
  #52
Volkert
Volkert's Avatar
Well, that at least solves one riddle! Yes, convertibles have their own series of serial number, however only in the States. ROW does not differentiate between cabs and coupes.
So that would mean yours is serial number 89 for MY98 NA Cabriolet!
Cheers!
Old 05-17-2017, 05:07 PM
  #53
Montychristo128
Montychristo128's Avatar
I have an inservice date with dealer stamp of 22 May 1998, so clearly built before that.
I will check car when I get it back from the engine rebuild for a build date.
Old 10-30-2017, 06:13 PM
  #54
gnarbowski
gnarbowski's Avatar
I didn't check mine before I shipped it off to FSI, but that wouldn't have mattered anyways. Jud at FSI looked inside my door and examined the entire vehicle and has concluded the sticker is gone. The vehicle could have been repainted, but I doubt it. The carfax doesn't indicate any accidents and the paint has plenty of chips, but a lot can happen in 19 years.
After some digging, I've pinned it down to a 9/98 build. The dealer had two dates in their system for the vehicle, 9/2/98 and 9/14/98. I thought this was odd, but who really knows. There is also a 7/98 build on here with xxxx3481, while my car is 9/98 with xxxx3633 for a vin. Makes sense, right.
Old 10-30-2017, 08:14 PM
  #55
Coopduc
Coopduc's Avatar
Just bought a 1999 roller, 3/98 build with 59k miles on the clock. So much for the early cars having better engines.
Old 10-31-2017, 11:27 AM
  #56
Volkert
Volkert's Avatar
Who told you that? They have a reduced chance on IMS bearing failure (due to double row design) and bore scoring (due to better temperature mgt etc). It does not mean they are failure free, especially when 18 years old... They do have a 4th/5th timing chain, lack of oil changes related issues etc etc (24 modes of failure....). You can still overrev them, cooling issues due to failing waterpump, clogged radiators...
Old 11-04-2017, 01:58 PM
  #57
AdamIsAdam
AdamIsAdam's Avatar
Received 4,032 Likes on 1,745 Posts
What I understood on why early 996 are the ones to have:
- double row IMS
- better alu casting for engine
- more balanced cooling water flow through the engine (compared to mk2 3.6L engines)
- throttle cable (C2 only) iso e-gas
- no ***** glove box! No cup holders!
- still can open frunk / boot with flat battery
Other?
Volkert
7/98 for me.
And a real dipstick! Aren't they lighter than later years as more electronics were added?
I didn't even pick mine up yet and I'm already loving it!
(PS I just ate fried eggs for breakfast)
Old 11-04-2017, 03:51 PM
  #58
gnarbowski
gnarbowski's Avatar
The only good m96 is one that has been rebuilt with nickies.
Old 11-04-2017, 07:10 PM
  #59
Volkert
Volkert's Avatar
Originally Posted by AdamIsAdam
7/98 for me.
Understood the Mk.1 C2 body is 50kg lighter then the C4 body. With the Mk.2 they used the same body for C2 and C4.
Old 11-04-2017, 08:23 PM
  #60
AdamIsAdam
AdamIsAdam's Avatar
Not sure about that, but I read that the 996 was 50kg lighter than the outgoing 911 out replaced.
Quick Reply: Earliest production dates
