PSA: Be mindful of how you do your overhead wiring it can interfere w/ GPS
Old 05-02-2017, 12:51 PM
Daohaus
Daohaus's Avatar
Default PSA: Be mindful of how you do your overhead wiring it can interfere w/ GPS
I have a dashcam that has a separate attachment for a rear camera that I have mounted at the top center of my rear glass. When I did my routing of this cable, I ran it across from the right side of the mirror and along the driver's side door seal and back to the camera.
Well I noticed that my GPS was acting all weird. Compass heading was totally off e.g. heading East but compass showing I was heading South. When I went to map mode on the PCM it was even more bizarre showing me cutting a swath across land and streets.
On a hunch, I thought I would disconnect the cable for the rear camera and within a second or 2 GPS corrected itself.
So it looks like I'll be re-routing that cable to go along the passenger side this weekend.
So dont be like me and run anything that has power/signal across where the mirror is mounted, your radio signal will degrade and so will your GPS.
Old 05-02-2017, 02:42 PM
StormRune
StormRune's Avatar
Just in case it helps you understand the location to avoid, here is a diagram showing the location of the GPS antenna in a 991. In the diagram, #1 is the GPS antenna, #2 is a radio antenna, and #3 is the GPS antenna cover (shield I assume).
Old 05-02-2017, 02:52 PM
Porsche_nuts
Porsche_nuts's Avatar
Received 1,184 Likes on 711 Posts
I have both front and rear dashcams. I run the wiring for the front camera along the passenger side headliner and the wiring for the rear camera along the driver side headliner. I've had no issue with my GPS or weirdness with maps.
Old 05-02-2017, 02:56 PM
Code
Code's Avatar
Good to know!
Old 05-02-2017, 03:37 PM
Daohaus
Daohaus's Avatar
This is perfect thanks for the pic!
that's interesting, I'm not sure if it's acted weird all this time or I just took the time to notice compass lately but that's definitely the cause in my case.
Quick Reply: PSA: Be mindful of how you do your overhead wiring it can interfere w/ GPS
