where to get tool 9186 or equivalent?
Old 01-31-2017, 09:16 PM
Dimi 944
Dimi 944's Avatar
Harbor freight offset box wrench does just fine.
Old 01-31-2017, 09:19 PM
Otto Mechanic
Otto Mechanic's Avatar
Originally Posted by fasteddie313
What you need to understand is that BMW, Porsche, Mercedes, VW & Audi were all designed to be assembeled and repaired using Stahlwille and Hazet tools.
Thanks very much Eddie. It may seem obvious to you, but us amateurs don't have easy access to that sort of information, it doesn't show up in manuals so we end up for many days until we either encounter advice like this and "see the light" or we invent something that more or less works
We all appreciate you sharing that wisdom, it isn't easy to come by.
Old 01-31-2017, 09:38 PM
MAGK944
MAGK944's Avatar
Originally Posted by Otto Mechanic
"Never had a problem using a deep 22mm socket turned with a wrench combined with a long 6mm hex held with a ratchet."
Nice set up, hadn't thought of that one. How are you reaching through the wrench/socket with the allen key? A socket cap wouldn't work...
The 22mm socket is being turned by the wrench (not the ratchet) and the ratchet has a long 6mm hex attached that reaches through the hole in the socket to hold the strut rod.
Old 01-31-2017, 09:45 PM
Otto Mechanic
Sorry Mike, I still don't get it.
How is the socket attached to the wrench? The only way I know of to do that is with a socket cap. Is the wrench an offset? If a cap is used, there's no way to pass the 6mm key through it?
Old 01-31-2017, 11:05 PM
MAGK944
MAGK944's Avatar
It's all about the type of 22mm socket used 👍
Old 02-01-2017, 09:27 AM
Van
Van's Avatar
Impact gun?
Old 02-01-2017, 10:59 AM
Otto Mechanic
Well yeah!
What is it you call a socket like that?
Old 02-01-2017, 12:44 PM
MAGK944
MAGK944's Avatar
Well yeah!
its a regular spark plug socket afaik.
Old 02-01-2017, 01:27 PM
thomasmryan
thomasmryan's Avatar
the top of the koni inserts will have an 11mm instead of an allen.
I use the offset O2 sensor socket that has the 1/2" drive on the side which leaves access to your holding tool.
Quick Reply: where to get tool 9186 or equivalent?
