Hi guys! My first post here and I'll start with a question. What is the color of your coolant looking down into your reservoir? I have a 2013 C2S with 41k miles on the clock and was shocked looking into the reservoir to see it extremely low and copper brown in color! After looking online it seems like the lifetime coolant we use is prone to getting brownish, but I'm curious if someone has a similar looking coolant color? And is this normal?
On a side note. How frequent do you guys need to top up your coolant? I've owned the car for 3k miles and I'm new to the quirks, and habits these cars have.
Check where the top of the red bobber is located. If it is in the opening toward the front of the car, add mix (50% Porsche coolant, 50% distilled water) until the bobber top is centered or towards the rear of the car.
When I looked at the liuid in the reservoir of mine, the fluid looked brown. I got a straw and pipetted some out and put the liquid on clean white paper towel. The liquid was pink, like it should be. The muddy look in the reservoir is likely just an artifact of the plastic and the reservoir location.
