#5026
I picked up a '12 997 4S this weekend and I will be selling my '09 997 Carrera. Currently, both cars are in the garage with their rear ends removed as I'm swapping over my ceramic coated Fisters, Sharkwerks X pipe, Fabspeed intake and exhaust tips. Always fun to work on two cars at the same time.
I'll post pictures once finished.
#5027
Leather parts weren't cheap but they were a nice upgrade to the shiny/scratched plastic they replaced. I'm having Porsche replace the door handle surrounds this week. I took the door panel off but it looks like the current pieces have plastic welds on the back. I'll update once completed. Cheers!
#5028
#5029
Not in MA anymore
Pete - I would love to see how you did that. I'll be doing a replacement this year and your method sounds like a great solutions.
Thanks and Happy New Year
Matt
Matt
Looks very nice. A couple years back I did a DIY post on replacing the door spears melting the original welds and replacing them with screws from the back side to fasten the new ones. The screw method is great because you can independently adjust the tension of how the spear fits to the panel at all the attachment points. It's not too difficult and would probably save you a good bit of money over having the dealer do it.
If you're interested, I can recap the process. I think the photos are on my home PC though so wouldn't be able to share those until Tuesday.
#5030
https://rennlist.com/forums/parts-ma...-trim-kit.html
#5031
dirty car cell phone pic but nevertheless.. drove my wife down to key west for new years in it
#5032
Refinish scratched trim
So I was going to have my console and door plates covered in leather but found this how to:
Porsche 997 Ash Tray Paint Repair
This guide will show you how to repair a very common issue among 997 and 987 owners. The interior plastic paint tends to peel around the ash tray (and other areas) We will remove the original coating and then proceed to repaint the affected area.
We will remove the original coating and then proceed to repaint the effected area.
Tools
Preval Sprayer
Step 1 — Porsche 997 Ash Tray Paint Repair
Ask home depot paint rep to mix a sample paint pot in the Interior color using the ash try as the sample.
Step 2 - Optional
Apply Lacquer thinner and begin to remove paint.
The paint will softened and being to bubble up , just keep working the paint with lacquer thinner till its all off.
Step 3
Wash the plastic piece with some dishwasher soap to remove any residue
Step 4
I sanded the part lightly with some fine sand paper (220-300 grit would be good) to remove any imperfections in the plastic
Step 5 — Prepare Paint Area
This is water based paint, so clean up is relatively simple... just lay down some newspaper or towel to protect the work area.
Step 6
Mix the Latex paint 3 parts paint : 2 parts water inside the Preval Sprayer
Lay down even coats of paint on the trim piece.
When spraying, never start or stop on the trim piece... always over spray it slightly.
I laid down 2 thin coats and the part looked great.
Let Dry And reassemble ash tray
Tools
Preval Sprayer
Step 2 - Optional
Step 3
Step 4
Step 6
#5033
I pulled my 997 out of storage today, since the forecast showed a couple of warm days for the early part of this week. My car's been in storage since Thanksgiving, since I only have summer tires and temps have been below 40F, so I've missed being able to drive it. Tire pressures had dropped, so I pumped them up. Tomorrow, I plan on washing the wheels, since I didn't get a chance to do that when I washed the body last month. Looking forward to Spring already!
#5035
Sir Thomas Lord of All Mets Fans
T
#5037
997.2 tail-off.
A pit picture heavy, but here is my Sharkwerks X pipe and Fister swap between my '09 Carrera and the '12 4S. It was interesting to see how similar they are but also the subtle differences. As most projects go, it took longer than expected but the pregnant wife was very patient with me spending the weekend in the garage.
Before:
Before:
#5040
Mike, it's good to see another Raleigh member. I hope to meet you at a Cars n Coffee this spring. Maybe you, GoPirates and I can meet up for a beer sometime.
BTW, I just ordered the Billy Boat center muffler delete. I may be PM'ing you in the next couple of weeks to get some pointers on how to remove the rear bumper.
BTW, both of your 997s look great.
