997 Turbo Forum 2005-2012
Will these center lock wheels fit a 2012 TTS
Old 12-11-2016, 12:24 PM
johnbelk
johnbelk's Avatar
Default Will these center lock wheels fit a 2012 TTS
Any ideas If these will fit a 12 TTS with center locks
8.5 X 19 ET 53
12 x 19 ET 63
They're for a GT3
Thanks JB
Old 12-11-2016, 01:34 PM
nzskater
nzskater's Avatar
From this site: http://www.1010tires.com/Tools/Wheel-Offset-Calculator#
Inner Clearance (the inside of the wheel to the strut housing): 25mm LESS
Outer Position (position of the outside edge of the wheel): EXTEND an extra 1mm
From those results I'd suggest you'd need a 25mm spacer to prevent any inner conflicts/rubbing. Don't quote me on that though as I'm unsure if we can push a wheel out by 26mm.
Old 12-11-2016, 02:00 PM
djillusion
djillusion's Avatar
They aren't ideal.
Old 12-11-2016, 02:10 PM
johnbelk
johnbelk's Avatar
I forgot to mention the are for Center Lock fitment...which would rule out spacers I would think.....right???
Old 12-11-2016, 02:22 PM
johnbelk
johnbelk's Avatar
I forgot to mention these are for a Center Lock fitment...which would rule out spacers I would think.....right???
Old 12-11-2016, 03:24 PM
djillusion
djillusion's Avatar
You cant use spacers with CL wheels.
Old 12-11-2016, 04:52 PM
johnbelk
johnbelk's Avatar
This is the OEM CL Wheels Specifics...on my 997.2 TTS.
8.5JX19" Offset: 56mm
11.0JX19" Offset: 51mm
My goal is to stay with 19's push a wider wheel/tire or offset to the fenderwell lip...and lower the car..
With my 997.1 5 lug, I had options, w/ these C/Ls I need to nail the combination.
I really don't want to drop a ton of $$$$$ and used wheels are fine...but really would like to know from someone's personal experience what will work...without issues.
This pic is from an RLer...the wheels are 20...but the fitment I'm searching.
Thanks JB
Old 12-11-2016, 05:38 PM
djillusion
djillusion's Avatar
With my HRE 590RS they are a perfect fit for the 997.2T with CL. Offsets are dead on and fill the wheel wells perfectly.
Even in 20", due to then lips, they look perfect on the Turbo.
My specs are:
Sizes and Offsets: 9x20 et. 53mm & 12x20 et. 48mm
Old 12-11-2016, 05:57 PM
johnbelk
johnbelk's Avatar
My specs are:
Super Helpful...thanks!!!
Old 12-11-2016, 06:30 PM
alpha motoring
alpha motoring's Avatar
You can go to a 20x12 ET43 safely
Old 12-11-2016, 06:45 PM
johnbelk
johnbelk's Avatar
Pushing it to the fender well...with a 325? You have these on?
What arout yoyr fronts?
Thanks. JB
Old 12-12-2016, 12:20 AM
djillusion
djillusion's Avatar
no worries! i run 325s in the rear. i don't rub but don't have any suspension mods/work done either. 245s in up front. wouldn't mind being just a tad lower, but I'm not messing with suspension on this car.
pics here if you want to see some more:
Old 12-12-2016, 12:46 PM
johnbelk
johnbelk's Avatar
"You're feeling very sleepy, your eyes increasingly becoming heavy." "That's right, you're in a deep, deep, sleep..." "Now, unmount your wheels and ship them to JB in NC...also, cook your dog a filet mignon ...."
Amigo, this is perfect... I'd rather not lower the car, so the pics are a huge help. Big thanks!!! JB
Old 12-12-2016, 01:52 PM
TypeRx
TypeRx's Avatar
Just sayin'..... https://rennlist.com/forums/parts-ma...-tires-cl.html
Old 12-12-2016, 02:24 PM
alpha motoring
Thanks. JB
20x9 ET56
I think the fronts can come out more, the rears with a 325 is flush, can maybe come out an additional 5mm, never tried.
I'm on stock fenders, no roll. Lowered and never rubbed.
Quick Reply: Will these center lock wheels fit a 2012 TTS
