About to buy 997, looking for advice on a scratch..
Hello all,
Long time "almost" buyer about ready to pull the trigger...
I love the 997.1 year cars, and have long sought after a midnight blue/sand beige manual. During a recent search I found a few which fit the bill. I decided to take the next steps on a 2007 997.1 Carrera with 61,746 miles.
Here are some pictures of the car.
I am located out of state so without looking at the car I went ahead and scheduled a PPI through German Specialties in Oldsmar FL. Leo did what sounded like a good job and I got a favorable report, barring a few items. Here is the complete rundown..
Along with my notes..
Bottom line the car ran strong through all the gears, and was described as "solid" and "looks good" by Leo at German Specialties. The major list of bads...
The 60k service is relatively routine, I am not too concerned with that. The clutch chatter is not a deal breaker, I was told there was no slip. The rear main seal is not leaking so it still has life. I would do that when I do the clutch as they are right next door. Good on the overrevs, fine on the rotors, tires are a fixed cost. The big no-no for me right now is the scratch...
Somebody clearly keyed this car and that is a disappointing reality to have to live with every day. If I were to purchase this car that would be an immediate fix. I have absolutely no clue the cost or capability of repairing this. It is deep enough to catch a fingernail on (I am told) so not just surface level. The midnight blue metallic I believe will be a tough or even impossible color to match. Am I correct in this thinking? If the scratch cannot be fixed perfectly I am not interested in the car and will have to keep searching.
I would love to gather more opinions on both the scratch and the results of the rest of the PPI. I have reached out to two paint guys for estimates but no results yet. Is it possible to match this color? What do you think, spot correction or respray of the whole hood? Any input greatly appreciated! Thank you all.
- Missed 60k service, currently at 61k miles
- Clutch chatter in 1st and Rev
- Seepage at rear main seal. NOTE: this was described as just wettness, no dripping, and not a major problem
- 2 overrevs (range 1 and 2, no big deal)
- Needs rotors, needs tires
- Major scratch on hood...
Based on the condition of this 997, you should be able to purchase this car for around $28K - $33K but you will obviously have to address the missed routine maintenance. Getting this car up to current standards will cost you a lot of money. Between the 60k mile service, new tires, rotors and pads, clutch and flywheel you could be looking at something in the ballpark of $4k - $6K.
I would walk away from this one unless the dealership is willing to meet you halfway.
Again, appreciate your opinion. Thanks for chiming in.
Scratch looks pretty deep - probably needs a repaint of the hood instead of touch-up. A good paint shop will be able to match. I had always heard that darker color repaints are easier to match than lighter color. Probably looking at $500+
Franky, thanks for your input. I am certainly glad I posted this here! I am most curios about the cost and possibility of the paint repair. The maintenance seems relatively routine and any capable Porsche shop should be able to do a good job, but the paint? What is the likely hood of a good job being done with the midnight blue metallic?
Any paint and body shop or collision center can repair that. They would do the entire hood for around $800 - $1400 depending on the shop. Matching the paint is not that big of an issue like it was back in the days. Most paint shops do a good job at looking up the paint code and matching up the paint.
I was NOT expecting this to buff out but I just received these shots from the dealer. I am impressed, the scratch seems imperceptible? Will this all coming to light - how does this change your opinion of the car?
EDIT: A side note. I contacted CPR out in Fallbrook, CA about the paint work. http://cprclassic.com/contact.html Mike was incredibly helpful and took me through the details of how the repair would work. He recommended shooting the hood as a whole, though he had done a local repair on a similar problem'd white 930. He informed me of advances in the paint and how close they were able to match these days. They can continue to respray the hood until the difference between panels is non-existant, but more often than not with all the prep they do only one spray would be needed. This answered my question about whether a scratch of this nature was repairable. In short, yes. ^^ is seems I won't need to go that route though..
I think the 60k service is plugs and fluid flush and oil change. Air filter and pollen filter, both are easy to do. Plugs and brake fluid flush is not. If you want to keep it a while get all the things done if not then do the minimal things
That scratch looked like just in the clear coat.......easiest way to tell is wet it and if it disappears then it can be sanded and buffed out, no biggie.........if it doesnt disappear then its into/ thru the paint. Now you know all the minor ones are very easy to correct.
iiAtlas - I have always wanted a dark blue Targa with sand biege. Was in the market for years...964s, 993s (not 996 ;-) ) but very hard to find and then I would dilly dally (or not have the funds). So after I suppose about 25 years pulled the trigger last year.
One thing I wish I had known (and would wait for) is to have a bicolor interior. Having a black dash eliminates a ton of glare. Mine is all sand beige and it is distracting from a glare stand point. Just something to consider that I never did.
I have good feelings about this 997. What about you all?
iiAtlas - if the full sand beige is your dream I completely understand and respect that. Hopefully I haven't planted any seeds of disappointment! My M5 is black and "tan" (caramel) which gave me something to compare it to.
You are going to be very happy I think. Midnight blue is a great color; it almost has a purplish cast to it in certain light. Mine is also a 2007 and I absolutely love it - still get excited every chance I get to drive her.
As an aside, if you want to see the options on your soon to be car, replace the VIN on this site (it will pull up a print window, just cancel that).
https://admin.porschedealer.com/repo...AB29938S730383
Good luck with the purchase!
Spark Plugs
Engine Mounts
Rotors and Pads
Coolant Flush (I noticed in the picture the current coolant is low)
Brake Flush
Steering Fluid
Clutch and Flywheel kit
Wiper Blades
New Tires
Wheel Alignment
Starter and Starter Cable replacement
Cabin filter
Air filter
Serpentine belt replacement
Radiator cleaning
Did I miss anything?
Keep in mind, the better the price, the more money you will spend on maintenance. These cars are wonderful put they are not meant for people with little money. Now if you have a mechanical background then they can be really easy to work on.
David, THANK YOU for the input. This is something I've considered heavily. I've even managed to find one sand beige / black headliner. Alas, the full sand beige is a childhood dream. I love the way it opens up the interior, feels like a whole world just for you. I may regret the decision but this is a dream I will have to see through Congratulations on the Targa, I absolutely love them and wouldn't hesitate to consider one!
