FABSPEED MOTORSPORT |718 Boxster / Cayman Sport Catalytic Converter
We wanted to offer the same benefits of the 200-cell HJS HD catalyst used in the Supercup Turboback exhaust in a smaller package. Our Sport Catalytic Converter is a great way to increase turbo noise and power while retaining a stock like exhaust presence - while being compatible with our Streetsport Catback at any time.
The portion of the exhaust that contains the catalyst is a rather large component, making a full replacement section costly. Our design incorporates a Torca clamp for easy installation into the factory double walled exhaust configuration - cutting is required for installation.
Fabspeed Motorsport is the largest distributor of premium HJS catalysts in North America, and second largest in the world. Based off years of engineering experience and ample testing we've selected the ideal catalyst to unlock performance from the factory exhaust system. This German imported 200 cell HJS HD catalyst is the top of the line solution to increase exhaust flow, resulting in a satisfying increase in turbo sound to match the extra horsepower gains. This specific catalyst has proven itself in numerous Ferrari and Lamborghini applications - able to withstand extreme abuse while preventing any check engine lights. The HD designation signifies the incorporation of a brazing stripe and special mantles to hold the metal matrix in place through the toughest of conditions while ensuring the overall integrity of the catalyst. The best part - increased performance without a check engine light.
Our Sport Cat retains the factory double walled design for perfect fitment and heat insulation. The included Torca clamp allows for both installation of the Fabspeed Sport Cat - but also reinstallation of the factory catalyst.
The addition of Fabspeed's Sport Catalytic Converter added 7 whp and 18 ft-lbs of torque peak power gains when tested on our Dynojet on a stock vehicle. 13 whp and 17ft-lbs at 4000 will make a significant difference in drivability.
Visit our product page here for all available options and pricing. We are standing by to answer any questions that you may have![/B]
Increase your 718s performance without fear of a check engine light!
We want the best for our customers which is why we use high-flowing, direct bolt-on 200 cell HJS HD German imported catalyst. These high-end cats not only give your 718 an increase of 7 whp and 18 ft-lbs of peak, but also 13 whp and 17 ft-lbs at 4000 rpm. Take a look at the dyno above!
Even though installing our 718 Boxster/Cayman Sport Catalytic Converter by itself will give you performance you can feel, the major gains will come when our software is applied.
We are still putting the finishing touches on our 718 software, so order your Sport Cat HERE to be ready for huge gains once our tuning drops.
Big gains come in small packages
If you have any questions at all, don't hesitate to contact me. The whole Fabspeed team and I are here to serve YOU.
