Favorite C2 Wheel/Tire Size Combo for track
#31
There's a a reason why Porsche didn't go any larger than the wheel specs I stated for their cup cars as well as sticking with the 245/305 wheel widths per the official cup car manual. You may or may not gain that additional edge past 305 on a 996 car but IMO, anything after 305 is a point of diminishing returns, not to mention fitment headaches that may not be worth it to some.
#33
One of my points and a pet peeve of mine is I see a bunch of guys always trying to squeeze the biggest wheel/tire combo as a trend. These guys often overlook or make a second priority of their driving, suspension settings, alignment, tire pressures. IMO, this is the wrong approach.
Also I'm a bit unclear on what you mean by 305 being an inch taller(taller than 275 assuming same sidewall aspect ratio?). Also just to clarify for others, these aggressive tire sizes may only work if you're running CO's. That's a very important factor to point out.
And by your same argument, Porsche never ran 305 on a c2. Porsche also never ran a VERY sticky 60TW tire on a c2. I bet it works a million times better than PS2s or whatever the OE tire is. Cup cars are a different animal. And I think (not sure) the tire sizes are based on racing rules more than anything else. They're obviously using different compounds. And comparing one manufactures 315 to another's 305 is REALLY splitting hairs. Your 305s (I hear Trefeos run really wide) are probably wider than my 315s.
In a nutshell, I love NT01s as a streetable track day tire for the reasons I stated in my other post. Best tire for my personal use. Within that tires available sizes, 315s are absolutely the fastest rear tire to set up a 996 c2 around.
Now aside from all that, how do you like the Trefeo R. I hear they're incredible and definitely would have ran them if I had the budget. How did they last/ perform?
#34
I agree with general idea of everything your saying, I'm just saying there is a very real, practical and adventitious application of the 315/30 18 NT01.
The Trofeo's are way overpriced IMO but they were meant to go head to head with the Michelin Cups so in that comparison, it's not really outrageous. I happened to stumble across a used set for a song that still had a few track days worth left in them, else I wouldn't have gotten them truthfully. These were my first experience with a tire of this kind so I don't really have any solid references. My last track oriented rubber were the star specs. They performed very well but my review doesn't really hold any weight. It's like asking a guy that's only driven accords or camry's on what they think of a 996.
#35
I've got a set of 305/35/18 NT01s in my garage I picked up when DiscountTireDirect ran the promo on eBay. I'm currently running Toyo 888 295/18s on 12" rear rims. I'm planning on installing the new tires soon. Reading this thread, it seems I should have picked up the 315/30s.
What negative aspects will I run into once I mount the taller 305?
Thanks.
Thanks.
#36
Thanks.
Thanks.
#37
Thanks.
Thanks.
#38
Got the new shoes put on today! 245/40/18 front and 315/30/18 rear NT01s on a used set of CCW C10 18x10et50 and 18x12et65. I had to trim some of the wheel well liner away but had about 9mm's clearance between the rear wheel and caster arm. Next track day is a week from Friday!
#39
You ran 10s up front! Hell yeah. I have 18x10s being shipped tomorrow for the same tire. I was worried it might be to stretched. But check your lock to lock up front. Make sure it's not rubbing the brake line or thrust arm at full lock. I'm running a more aggressive offset. Car looks stuffed! I love it.
Edit: I'm pretty sure those are 8.5s up front. It looks more pinched on your wheel than my 9".
#40
Crap, now that you say that I think they are actually 18x9. They measured 10" outside the lips. Sorry about that.
And they are mm's from my KW's. The extra 1" would have to go out if it was there.
#41
That makes sense. Would you believe I bought these without the guy even knowing the size? He listed this tire setup on them on a GT3 and made me a smokin deal on them. I figured they would either work or I could easily get my money back out of them.
#42
That's an awesome fitment, as long as everything is clearing. Definitely about the most rubber you can fit under a narrow body without body modification.
#44
#45
