3-Way Connector that is....I'm trying to sort out the vacuum tube routing for a 2001 911 996 Tip Cabriolet. In the diagram below, I'm looking to verify the following:
1) Where does the line label #29 go?
2) Does #19 plug directly into the changeover valve and is it the connection point that comes straight off the end of the valve (or the one comes out of the side)?
3) Does the other connection point on the changeover valve route to the rubber collar on the intake?
