I removed some plastic this AM to get access to the MC / ABS system and found the following:
Yep - that is brake fluid in those depressions. I guess that I could have spilled fluid in those depressions, but not sure how... Is the ABS unit leaking, does this happen 'normally' under heavy use (mostly track)? Any explanations?
Also the P/N that my Pet V7.3 shows is: 996.355.595.593, the Pet V6 is 996.355.955.04, and I have not found this number...
I also THINK I may have figured it out - suspect that I overfilled the brake fluid reservoir, things got hot, fluid escaped, and splashed around a bit...
