Key cutting
You can try AutoCle http://www.autocle.ca I use them for my key work at the shop or programming. Reasonable prices as well.
If for some reason you need programming it will be dealer only.
Finally got my key cut. Autocle is located in TMR very close to me. They also can supply keys and program them! Not cheap but still apparently less than the dealer. 😊
