997 differential shims for Quaife LSD install
Old 01-25-2018, 03:59 PM
halo777
halo777's Avatar
Default 997 differential shims for Quaife LSD install
I purchased a Quaife hellical LSD for installation in my 997. Details here... https://shop.quaife.co.uk/porsche-99...d-differential
Apparently, I will require shims for the installation. If you get the kit from Porsche, you have to purchase L&R, and it is big bucks. I have a found a partial set from a forum member, but it will still be quite pricey.
Does anyone know if you can use generic shims, or a place locally (Toronto) where they will only charge you for the shims you use during the installation?
Old 01-25-2018, 04:03 PM
halo777
halo777's Avatar
The part numbers from Porsche are
Part numbers: 997.332.266.00 (1.02-1.86 shim kit) right side
Part numbers: 997.332.268.00 (0.92-1.76 shim kit) left side
Old 04-09-2019, 01:59 AM
NATIAGAD
NATIAGAD's Avatar
Default Any luck?
Any luck finding them? I’m doing the same project and stumbled on this. I’d appreciate any advice. Thanks
Old 01-12-2021, 03:17 PM
halo777
halo777's Avatar
I ended up taking the car to the guys up at Autoselect in Newmarket for the install. IIRC, they said it was not an issue with the shims. I think they just ended up using the original ones
Are you located in the GTA?
Quick Reply: 997 differential shims for Quaife LSD install
