Web Forums still crawl at night
It's better now than it was, but after awhile, it goes back to 2-3 minute load times per page. Is it something on my end, or has Rennlist "hit the wall?"
It's getting to the point where I can't read the site at home at all -only in the mornings at work.
Hate to see this happen after all the work John D. has put in.
Alan
Alan
Actually..
It's not at my end.. For example - here you go:
Tracing route to cpe-66-61-117-6.neo.res.rr.com [66.61.117.6]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms cpe-66-61-117-6.neo.res.rr.com [66.61.117.6]
2 16 ms 16 ms 14 ms cpe-66-61-117-6.neo.res.rr.com [66.61.117.6]
3 108 ms 116 ms 94 ms cpe-66-61-117-6.neo.res.rr.com [66.61.117.6]
4 81 ms 108 ms 72 ms cpe-66-61-117-6.neo.res.rr.com [66.61.117.6]
5 120 ms 114 ms 125 ms cpe-66-61-117-6.neo.res.rr.com [66.61.117.6]
6 138 ms 109 ms 94 ms cpe-66-61-117-6.neo.res.rr.com [66.61.117.6]
7 93 ms 141 ms 186 ms cpe-66-61-117-6.neo.res.rr.com [66.61.117.6]
8 112 ms 94 ms 72 ms cpe-66-61-117-6.neo.res.rr.com [66.61.117.6]
9 53 ms 49 ms 49 ms cpe-66-61-117-6.neo.res.rr.com [66.61.117.6]
10 81 ms 54 ms 54 ms cpe-66-61-117-6.neo.res.rr.com [66.61.117.6]
11 94 ms 63 ms 54 ms cpe-66-61-117-6.neo.res.rr.com [66.61.117.6]
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
Further - if you go here:
https://rennlist.com/forums/
There are about 900 folks logged in and posting??
Best to you,
John
Best to you,
John
Wierd. Back to fast for me this morning. The past couple evenings Rennlist has been extremely slow, but all other sites, MSN, Yahoo, Bimmerforums, etc, has been fast. The other interesting part is that the Rennlist header and menu frames load very quickly, it is just the forum frame itself that takes so long.
And this evening??? If you see this - post back, OK?? There is another in OH that is having a similar problem - but only in the evenings?? Very weird!!!
Hmmm..??!!
JD
Hmmm..??!!
JD
John;
now it's back to "normal"- and it's a Saturday night, no less. First time I've been able to read the furoms from home in weeks. Very weird - somthing in the pipeline?
Alan
Alan
Hey Alan..!
Not sure - but, I haven't touched the server/routers/circuits at my end since last week?? Very strange..!! Can you post back in this thread every once in a while - just so I can keep tabs on it?? Thanks!!!!
John
John
Another data point. When I switch from one forum to another - Racing to 944 Turbo for instance - the load times are about 30 seconds. Much faster than last night but this morning it only took 1-2 seconds. However when I open a specific thread whithin one of the forums, it only takes 1-2 seconds to load.
Hey guys,
Well - now that makes FOUR of you from OH..??!!! Can you please post back your ISP that you are using - and the connection type? Like:
I'm an rr.com customer with a cable modem....
Thanks!
john
Thanks!
john
Time Warner/RR - cable modem. Quite slow tonight. ~ 2 minute load times. For comparison Bimmerforums have 3,000 users online right now and load time is 1 - 2 seconds for me.
I have been having slow 964 forum loading for a few weeks now. I thought it was my house. As the others, I check it in the morning at work and its fine. The 964 forum takes a few minutes and sometimes it does not load. The banner loads fine but the forum frames do not.
Strange though that this help forum loaded relativley quickly. Allt he other websites I go to load as fast as normal.
I use Time Warner Cable modem in Powell OH.
