damn I know im not the smartest guy around but....
how the hell is one supposed to interpret the statement...
"the maximum size for your avatar is 300 x 250 or 96K pixels, whichever is smaller..." think on it for a second... |
This is the quote:
Note: The maximum size of your custom image is 250 by 300 pixels or 19.5 KB (whichever is smaller). I think this is self explantory |
OK so if your image ia 300 x 250 but the size is 1K
the maximum size is 1K?
No. A color jpg does not have only 1 bit per pixel. Much more than that.
i know that
it was a hypothetical to illustrate the parodox.
The point is my avatar is 300 x 250 and its saying its too big so I guess i have to try to simplify the colors |
The point is my avatar is 300 x 250 and its saying its too big so I guess i have to try to simplify the colors If you're saving as a JPEG and the output file is too big, try setting the image quality to "medium" instead of "high" (medium quality loses some detail but has better compression and produces smaller output files.) |
You can have the picture at the same resolution but increase the jpeg compression to make the file smaller...
the paradox is...
Originally Posted by wross996tt
What paradox? If the image meets the dimensional requirements, but requires too much "disk space/memory" then you need to downsize it (as suggested above). If the disk space is small enough, but the dimensions are too big...you need to down size it (it takes up too much real estate)...what paradox? (these are two different specifications).
"whichever" is a word? :confused:
thank you Icon....
I was too tired to explain
I don't get it because my former avatar was a LOT bigger
i think if you host it offline, at like, www.imageshack.us or photobucket.com you can make it bigger. |
brett,
still limited by 250px wide x 300px tall even when linking! i have seen bigger ones though, that may have been put in place b/f the max's were set. best jeff |
Originally Posted by icon
brett,
When you folks figure out what the problem is - could one of you send me an e-mail on the "condensed version of the Avatar fix"?
This statement "The maximum size of your custom image is 250 by 300 pixels or 19.5 KB (whichever is smaller)".. makes perfect sense to me....?? But what do I know - I only host and program this site.... ;) Thank you..... |
