Time Offset Feature
Time Offset Feature
JohnD: you wrote in 2003: The "system time" is set to Eastern Time - rather than GMT. Therefore, if you want the time to display correctly for your location - choose the time OFF SET from Eastern US Time in your profile, rather th[a]en GMT (yea, I need to reprogram that drop down menu - I know...)>>
It is not set to Eastern. I don't see "Time Offset" or whatever selection would fix this in my profile window. If you can't note in the time window what zone it is set for, (which would be the simplest solution), i.e., Greenwich or what ever it is set for, then can you update these instructions please?
