Garage car lift questions...O/T
#31
Is it just the bolts in the concrete that prevent the 2 posts from collapsing into the vehicle? Did you reinforce the garage floor when when it was being poured?
#32
Cardigan Millionaire
For concrete it has to be 4in think and have a compressive strength between 20 and 35mpa
#33
Yes it's just bolted to the floor with the supplied wedge anchors. Jordan is right you need at least 4" of concrete. My house is a custom build and the original owner overdid everything. My garage floor varied, floor measured 5-6" thick. The lift is rated for 6000 lbs.
#35
It appears to have a mechanical manual safety release system. No idea how that works exactly but quite a few have them. My bendpak 4 post is pneumatic release which I like. Just make sure things are fully released when you drop a car otherwise it’ll get lopsided.
I wouldn’t worry much about the concrete. That contact patch isn’t much different than a tire.
One thing to keep an eye out for is if there’s a pitch to your floor. Front/back. You want the car level going up and when in position which means at the very bottom of your floor isn’t level then you’ll have to figure something out.
#36
lolwut.
Also, someone mentioned 4" of concrete base previously.
better them than me.
We had the builder pour 7" but really only needed 6
#37
Wrong thread
#38
https://www.bendpak.ca/car-lifts/parking-lifts/pl-6kdt/
Love this solution for a double car garage and not having any posts in the middle.
When I build my laneway suite, I’m going to consider it
#39
^Probably rather have 2 auto stackers in a residential garage.
