Power steering rack rebuild in Toronto Area
Can anyone recommend place for power steering rack rebuild in Toronto Area? I might need some work done on the ZF power steering on my 951.
talk to Hunter, or you can get a rebuilt one here http://www.rockauto.com/en/catalog/p...lete+unit,7388
You can buy the seal kit and do it yourself. Not a hard job to do if you are mechanically inclined and have the time:
http://944online.com/index.php/front...-seal-kit.html
Check all your lines, pump, reservoir, belt, and belt tensioner before you dive into the job. Chances are it will be a good time to change some of these as well...
Good luck.
P
Good luck.
P
