Dragged home one of these.
Old 07-12-2012, 01:27 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Good point Clive. I will post pictures of the pieces later on.
Old 07-12-2012, 01:49 PM
jumper5836
jumper5836's Avatar
Do you have a borescope. I'd pull the plugs and look at the cylinders. Also note how each plug looks compared to each other.
Old 07-12-2012, 03:04 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Don't have one but know someone that does.
Old 07-12-2012, 07:36 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,021 Likes on 726 Posts
imre gonna head over in a bit for a look
Old 07-12-2012, 11:18 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Clive, sorry, didn't see this till now. I was over at my brother's refilling the AC on the tow vehicle.
The AC clutch bearing went just outside of Chichago when we already ahd the 996 in the back and had to replace the entire unit in an Autozone parking lot. We were lucky they had one in stock. Then we there was a blowout on the trailer just before Cleavland.....it was an eventfull road trip, but we made it.
I'll be home tomorrow evening, come by.
Old 07-12-2012, 11:48 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Pics from the other night. The black oval is a magnet. Very few small specs of metal. The middle of the oil pan are the plastic bits. Filter cut open looked clear of any metal.
Old 07-13-2012, 05:46 AM
ronnie993tt
ronnie993tt's Avatar
Plastic bits may = water pump failure? Any plastic in coolant? Not sure how they'd get into oil....ah what the crap do I know?
Old 07-14-2012, 03:41 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Did some duagnosys and the engine is coming out. Bank 1 (driver side) has 0psi and Bank 2 cyl#4 has 90psi and cyl#5 has 30 psi.
Didn't bother cheching the rear most cylinders to compression. All the plugs look ok, the electrodes aren't smashed and there is no sigh of excessive oil burnig either. Something happened to the cam timing and there must be some bent valves. Coolant looked good and clear.
Old 07-14-2012, 10:42 PM
Revn29k00
Revn29k00's Avatar
Looks like a fun project. Looking forward to see what you do with it.
Old 07-15-2012, 09:06 AM
996_North
996_North's Avatar
What is the serial number on the motor..interested to know if this is the original motor or already a remanufactured one ? This is a great thread, thanks for starting it Imre. The journey seems to have started before you even got it home
Old 07-15-2012, 10:47 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
I saw one non factory zip tie holding the main wiring harness down so the engine might have been out before. Where is the block number on these engines?
Old 07-15-2012, 02:32 PM
theiceman
Team Owner
theiceman's Avatar
I'm thinking timing skipped a tooth because of tensioner or ims sbaft is ratling around coz the bearing is toast.
I'd have those pieces of plastic looked at. Colin if you still have hour bearing or Phil that may help. Imre can. Compare plastic and see if it is the same
Old 07-15-2012, 02:43 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
When I was under it yesterday, saw some signs of oil leaking at the back of the engine. Either the IMS or the RMS is slightly leaking. Not enough to drip but enough to collect dust. I'll be going out today too start removing things from the bottom. Everything from the top is dissconnected. Working on the trailer is so much nicer on the back. Almost as good as a small hoist. Clive, I kept some of the plastic bits form the oil pan. If someone has something to compare it to, that would be great.
Old 07-15-2012, 06:08 PM
fbgh2o
Odd Posts
fbgh2o's Avatar
Looks like you got some nice after-market mufflers.
Old 07-15-2012, 06:23 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Those are not stock?
Quick Reply: Dragged home one of these.
