Need a new clutch, shopping around
Old 08-23-2011, 07:28 PM
JoeFerg
JoeFerg's Avatar
Just to confirm,
M96.02 engines use the 32mm nut for bank 4-6 timing chain tensioner.
M96.03 engines use the #12 Allen buried under the A/C for bank 4-6 tensioner.
I tore into a MY 2002 M96.03 engine today for another LNengineering IMS kit install, A/C compressor needed to be taken off the engine to get at bank 4-6 tensioner.
Also, I didn't catch on before to what SharpMan asked. 06+ engines were updated by Porsche using a much larger IMS bearing. Easily identified by the larger 22mm nut in the center of the IMS flange.
There is no way to remove this later version IMS bearing without spliting the case. So hopefully Porsche got it right this time.....
Old 08-24-2011, 12:03 AM
dc88
dc88's Avatar
Originally Posted by JoeFerg
Just to confirm,
How about MY05 997.1? Was a larger IMS bearing used or is a 05 simply a 996 with a new skin?
Old 08-24-2011, 12:48 AM
JoeFerg
JoeFerg's Avatar
You'll ned to look at the bottem drivers side of your engine block. you will see a stamped number either starting with M96 or M97.
From my understanding all the M97 engines have the updated larger IMS bearing. Being that yours is a MY05, it may still be the M96 engine which has the dreaded smaller, known to be hit or miss, IMS bearing.
Worth a look at the engine number.
Old 08-24-2011, 09:56 AM
theiceman
Team Owner
theiceman's Avatar
Received 1,012 Likes on 719 Posts
Originally Posted by PPo
Uli is a great and standup guy... and without question one of the best and fastest track drivers you will ever meet... at his best he would put more then a few pro drivers to shame.
i could counter that point .. but will not do it here .. buyer beware
Old 08-27-2011, 09:57 PM
PPo
PPo's Avatar
Fair enough, and I certainly won't dig deeper... but I assume you are not talking about his driving!
Quick Reply: Need a new clutch, shopping around
