Reasonable brake job in GTA
Team Owner
if that car has an electronic parking brake you may have to do research .. but outside of that brakes are brakes. there is nothing magical about Porsche brakes. Most people have a buddy who has done it before that can help. I know all my friends do . lol
speedstar
993c4_Toronto (07-16-2019)
Does that mean top end prices too?
brake job on these are easy peasy.
lots of utube videos. many recommend changing the caliper bolts, often sensors can be reused. you may want to bleed fluid while there.
yes shop around for parts. careful what pads you use as some stop much better than others and some have much more dust. These trucks are heavy!
MVS charges 108 per hour and should be able to do it pretty quick but doing it yourself is more rewarding if you have the time.
Cayenne brakes are so easy to replace .. Just order as per the list above and you are good to go ... I can do a set in less than an hour ...with a beer in one hand.
993c4_Toronto (07-17-2019)
we've had 2 different q7's (same brakes AFAIK) since 2012....
those germanparts.ca prices seem pretty good....
I recently went back to rockauto for brake parts.... I've been happy so far.
If the chassis design is the same as a q7... the fronts are no issue... the rears may have a caliper bolt that is really difficult to get loose (even with a lift)
parts list seems fine. get some brake cleaner if you don't already have and clean the sliders well. if caliper bolt is tough just use an extension and it will come out. Be sure to use jack stands
"Why do you think you need brakes and rotors"
The brakes warning light is telling me I need pads. I am planning to replace the rotors at the same time.
