Battery recommendations?
I am looking to replace the battery in my 997.1 S - Curious what other have used and had good results with
Thanks! |
im cheap so i get them from the wreckers.
Originally Posted by theiceman
(Post 15829854)
I just go to Canadian Tire and use whatever they have. Never had a problem.
Originally Posted by Ronan
(Post 15829903)
Canadian Tire Motomaster Eliminator. Perfectly good battery, cheap price and 5 year replacement warranty. Don't give this any more thought. Also, no you don't have to re-program anything after changing batteries (that question always comes up in replacement battery discussions for some reason...).
Edit: Or, Voltphreaks LiPo VPR6 - save 60lbs of weight, just $1500 or so :biggulp: |
Thanks everyone. I'll probably grab an eliminator
just did this last week, walmart. it was also was 10$ cheaper to the comparable CCA Canadian tire (mid grade) equivalent one.
battery will be an H7 / 94R.
walmart https://www.walmart.ca/en/ip/eversta.../6000195362562 Costco has them as well and a bit cheaper than Wal-mart. |
Canadian Tire Eliminator for me.
I just did this Cdn Tire branded for me, the tray in the 997 can take any H6/H7/H8 battery you just screw the clamp into a different location. My OEM original battery lasted 9 years which I guess is pretty good :-)
I use Interstate.
Canadian Energy
160 Cochrane Dr Markham, ON L3R 9S1 |
Originally Posted by bcrdukes
I use Interstate.
Maybe there IS something wrong with me, because my birthday present to myself this year is going to be an Antigravity battery.
No affiliation, just think its far easier losing 30 lbs this way then signing up for a gym I will never go to. |
