Shop recommendation for PDK clutch & transmission fluid change
I have a 09 Cayman s with PDK at around 73k.
I know the clutch is suppose to be at 90k and tranny is at 120k, but I would like to replace the fluid now.
I've read that you need PIWIS tool to put the transmission into fill mode, are there independant shops in GTA with the PIWIS?
Thank you
Thank you
My 911 did not require a filter pan replacement. I had it done by Mark's Motors Porsche in Ottawa for less than half of what you were quoted...
Thank you
Thank you
At your mileage, I would recommend replacing the drive belt as well, if you haven't already.
If you have a jack you can DIY it. I didnt have the cajones to be the first but this guy did......it Is not rocket science or mystical like everyone will have you believe. Its a transmission.
https://www.planet-9.com/987-cayman-...id-change.html
