2018 Best Caliper and Wheel Refinishing Toronto
Old 03-04-2018, 10:53 PM
TKEES
TKEES's Avatar
Default 2018 Best Caliper and Wheel Refinishing Toronto
Hey Guys - researched the forums a bit but nothing current. Who do you guys recommend in the GTA for Caliper painting (not powder) without a full rebuild and wheel refinishing? Can be separate, just want the best. Thanks
Old 03-05-2018, 12:08 AM
Pags993
Pags993's Avatar
No reco on wheel refinishing but Simply Tire painted my badly faded original black calipers and they did a fantastic job. 5 years later and they still look great! Not sure if they still do it.
Old 03-05-2018, 09:17 AM
strathconaman
strathconaman's Avatar
RE: Wheel finishing. Not Union Rim.
Old 03-05-2018, 10:17 AM
Adamant1971
Adamant1971's Avatar
I would caution that wheel re-finishing can be hit or miss. In the past union has done good work for me, but as per above not all have had the same result. I have also had Carcones do wheels but the last set of cup 1's they did for me were crap (totally chipped after just 2 seasons, thin brittle paint), the speedlines they did before that were put in the box still wet and marked the lip (but they owned their mistake and re-did them perfectly). Speedlines pictured.
Last year I had a set of cup 1 reps done by dream tire in Burlington with good results, but they took months and I had to hound them to complete the job. The car is not on the road yet so I can not comment on durability yet. Pictured below.
Lately I have been using Fireball up in Erin for both paint and powder coating of wheels and parts, but again I have had inconsistent results. On my last batch they had to re-do multiple parts due to bad prep and ignoring my marks for areas to not coat. But the calipers they did for the 89 build turned out very well, but they were powder coated and completely disassembled. Calipers and engine bits pictured.
I believe simply tire is still doing calipers, and they can probably do the wheels for you as well. They mounted tires on my cup 1's that carcones did and the paint chipped on the lip. They recommend powder coating wheels and I agree (as long as they can match the OEM silver).
Whoever you choose be very detailed in how you want things done, giving the shop a printed list of instructions will hopefully ensure a good result.
Old 03-16-2018, 07:29 PM
TKEES
TKEES's Avatar
Thanks guys! I figured it out, I’ll post pics when I get everything on the car next week.
Old 03-18-2018, 12:13 AM
Porsche-ah
Porsche-ah's Avatar
I've used Max at Leprecon wheel repair in the past with nothing but great results.
Give them a ring.
Old 03-22-2018, 06:33 AM
TKEES
TKEES's Avatar
Give them a ring.
Thank you for the advise.
Old 03-22-2018, 02:19 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
I've had my son's racing go kart frame media blasted and powder coated at a menonite shop (I kid you not) near Elmira and they did an excellent job. Saw several sets of rims waiting pick up when I dropped the frame off so they do them to. They powder coat pretty much anything (know someone that had a 50's pick up frame done by them). And they are cheaper than anyone around by far.
Old 03-22-2018, 02:46 PM
Adamant1971
Do you think they could match the OEM wheel colour? I need to get my cup 1's re-done. Contact info or address?
Old 03-22-2018, 03:02 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
I don't know. They have a display of colours (probably about 25 different ones) that they offer and you need to pick one from that. They don't seem to have a website but here is the Google search that shows a little about them: https://www.google.ca/search?q=simeo...w=1102&bih=400
Their contact info:
Simeon B. Martin Manufacturing (Sandblasting and Power Coating)
4198 Lavery Road, Wallenstein, ON.
519-698-2442
Old 03-26-2018, 11:41 AM
vetfever
vetfever's Avatar
I don't know. They have a display of colours (probably about 25 different ones) that they offer and you need to pick one from that. They don't seem to have a website but here is the Google search that shows a little about them: https://www.google.ca/search?q=simeon+b.+martin&spell=1&sa=X&ved=0ahUKEwjmuq7CwYDaAhUGUa0KHdz_ CA4QBQgkKAA&biw=1102&bih=400
Their contact info:
519-698-2442
Spoke to him this morning. He asked if the wheels were steel or aluminum (alloy). Said that results can be problematic with powder coating aluminum. Said that the finish can bubble because of off-gassing. He went on to say they generally have good results, but wanted to warn me they occasionally have had problems.
First I have heard of aluminum causing problems with powder coating. Anyone else heard of this??
Old 03-26-2018, 03:01 PM
Adamant1971
Improper prep or contamination during the process. It has happened to me, and the coater had to re-do.
https://www.finishing.com/313/22.shtml
Old 03-26-2018, 04:00 PM
vetfever
vetfever's Avatar
Thank You
The link talks about two things impacting the finish: contamination (fish eyes), and off-gassing (bubbles). So it looks like the gassing issue is "a thing".
Old 03-26-2018, 04:25 PM
Adamant1971
Thank You
Yes it is a thing, but IMO some coaters use that as an excuse to cover up bad prep or contamination (usually fish eyes that they then call off gassing to unsuspecting customers). Pre-heating is a good idea with Aluminum, this will help to drive out any gasses before the coating is applied.
Personally I would go somewhere else if they are not "comfortable" working with aluminum or if they say they do not pre-heat. But I have yet to find anyone in the GTA that will do work to my standards.
Old 03-26-2018, 11:18 PM
ggrace
ggrace's Avatar
For what it’s worth, this time last year, Pfaff Tuning quoted me $292.50 + tax per caliper to paint (uninstall, disassemble, paint, reassemble then install).
No clue the quality, but I’d expect great results from them.
Quick Reply: 2018 Best Caliper and Wheel Refinishing Toronto
