955-Oil temperature sensor
Hi everyone,
Does anyone know where the Oil Temperature Sensor is located on 2005- Cayenne S?
Please and thanks. If you have a photo, that would even help me better.
I've these codes P0197 and P0074.( which are the oil temp sensor and the ambient air temp sensor)
Thanks in advance.
Assirmal.
Thanks in advance.
Assirmal.
Bottom of oil pan its part of the oil level sensor... Look for broken or chafed wiring in or around the connector/ few inches back. If wiring checked out get a new sensor and replace
955-Oul temperature sensor
Thank you Gregster for your quick answer. Does this sensor have the oil level as well as the temperature a combined fonction?
Does the oil spill when I take it off( that way I can wait for the oil change as I just did one.
Thanks again in advance.
Assirmal.
Assirmal.
Yes, the ambient air is located inside the front bumper.
I meant, iif the that oil sensor has the two fonctions of oul temperature and oul level at the same time. The second part of my question was if I take off the ouls sensornto replace it, does it cause any oul spill or not.
Thank you.
Assirmal.
Thank you.
Assirmal.
