Need recommendation for alignment
Hey guys, can anybody suggest a shop for a 4 wheel alignment on a 997.2? Way out in the Far Far East end of Toronto, or even further East? I'm past Cobourg, need the rears aligned especially, and need rear tires too... Any suggestions?
that`s a classic 911 problem: a camber, potentially toe, and sidewall height issue
that`s also reasonable mileage (allowing that your alignment might need adjustment) for a sticky high performance tire on the back of a 911
lastly, the tire is borderline garbage in terms of rubber age at 4 years old
Go to MVS on Warden and 401 in Scarborough. Mario and Nick are there and Nick is top-notch when it comes to wheel alignment. They will set her up the way you want it.
+1 for Speedstar. As coop mentioned, Albert and Frank are top notch guys. They will sit down with you to explain exactly what they will do and how the alignment setup they're recommending will affect performance.
If your car is lowered then You need Adjustable Upper Control Arm and Adjustable Toe Links, an alignment and new tires wont solve this issue.
If not Lowered you need a Super Good Alignment only
Speedstar also a good suggestion, and closer to you - they are located in Markham. They are contracted to run DFC's IMSA cup car program. Contact Albert info -at- speedstar -dot- com
