performance friction 08 or Pagid RS29 brake pads
Hi
Thanks for all the info and advice on this subject, My car is not a Porsche, its a BMW M3 but I was finding very little about what people recommend on M3 forums other than everyone uses RS29's so done a search and this forum came up and the knowledge on this Forum seems a lot better regarding track use.
Im running Ferodo 2500's now but now really happy with them as the bite isn't great if I'm honest and the pad doesn't give confidence. I'm very limited with what Pad I can use for my Brembo Calipers, my options only seem to be PFC08, RS29's or Carbotech XP8/XP10's
I need to check to see if I can get the DS1.11 for my caliper
Thanks once again for eveyones help
If it's an F80 M3, Pagid makes the pad in both RS29 and RSL1. Most folks opt for RS29 and those pad shapes ( 4931 and 4933 ) have been very popular.
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
So what's the consensus on how to bed in RS29's on track? I have a brand new set of front pads and what I've heard is that the first session out basically accomplishes whatever bedding needs to take place. Not sure how else it would be done, actually...but this is the first set of new pads I've had that I won't be able to bed them in on the street.
Bedding is critically important for desired wear patterns and noise.
when you do it correctly, you will be happy with the results. you can do it on the track, VERY easily too.
Mark
I have a E46 M3 but I'm using a Brembo Caliper from a 1 series coupe 135i so I'm limited to only a few brake pads
RE: Bedding in
Hi Mark
Would you be kind to PM me your bedding in procedure? I can’t yet send PMs...
Thank you
Alex (UK)
Thank you
Alex (UK)
send me a PM and ill provide you the bedding process. what you mention is the conventional bedding process which is "good enough " for the track , and will not solve noise issues (and not fully live up to their wear and stopping potential) .
Mark
Mark
RS29 must be bedded in as specified by Pagid. PFC 08 requires no special bedding. Both will make road noise ...like a shreak when you apply brakes.
PFC 08 will definitely outlast Pagid and has more initial bite. Some of the faster cars GT4s and GT3s have told me that Pagid will no longer stop the car when you get down to less than 1/2 the pad.
PFC is pretty much good to the backing plate.
PFC runs hot on the rotors where RS29 runs cooler and is friendlier to the rotors.
IF you are doing mostly track stuff you should consider Ferodo DS1.11.....very friendly to the rotors,
must be bedded in and will schreech but the modulation and release is to die for. Of all that have gone from PFC or Pagid to Ferodo I have only had 2 guys go back......all the rest rave about the performance.
how come you have been leaving me in the cold.....
Paged RSL1’s are a nice step up from the RS29s. I was going to try the 08s or the Ferodos butIve been pretty happy with the new Pagid compound.
I think the 08s are a better choice as well. However, I have developed a very bullet proof bedding process that takes full understanding of why rotors and pads make noise ("screeching sound", even after the tradittional bedding and a track day or even race)
Ive been running (racing) the PFC11s for a few years now... 4-5 sets and have absolutely NO noise what so ever, and thats on a stock rotor and a 3 piece rotor. its all in the bedding process. Let me know if you want to know the process... if you havent had a track day on them yet, i can help.. after , its a little harder to bed properly to remove noise as the wear pattern is established.
the result is no noise, on or off the street or track.
Can you please PM your recommended bedding in procedure.
For a dual purpose car the Ferodo DS1.11 is an excellent choice. Clark talked me into switching to them a few years ago on my GT3 and I am still using them on the RS. Excellent initial bite and modulation. My car is 80/20 track/street and if you research the mu versus temp curves for them you’ll see a very flat, broad response curve making them great for street and track. They wear about 1 mm/day of front pad at Sebring which is acceptable. The front rotors are still looking good after 28 track days, so not hard on rotors as well. Yes there is short squeak on the street during the final few feet of stopping but I was never bothered by that.
key point here is PFC runs HOTTER.....a good 2 to 300 degree hotter.
pagid say the last backing plate thickness is the glue so need to be changed prior.
Ran PFC08 on one car - they were loud no matter what I did. I had to change them if I ever wanted to drive on the street. It was that bad. Then moved to PFC06 which were quiet but didn't have nearly the bite that the 08's did - though the modulation was better. Finally, I'm running PFC11's now. I really like them after about 9 days on track. Great bite, decent modulation, but man... they are hard on the rotors. I had (what I thought was) a set of fronts with 1/2 life left... not so much. Cracked the rotor on my last session clean through.
I've simply had too much luck with PFC's to make a real consideration to switch brands. Really, the one to talk to on this is Clark at Apex... he knows about everything there is to know on this subject.... he's steered me in the right direction several times now.
