Sears Point Race July 2017 Video incar cam- Group 3
Here is the first few laps of the Group 3 race. at about 10-14 laps , we had a car hit a wall and the last few laps were under caution.
fun weekend!
fun weekend!
Here is the rear cam view .. fun start and the nascar toward the end was getting his sea legs and finally blew by me with his 750HP. over shot turn 7, and then cam back on... pretty funny. I got a good laugh there.
Thanks Mark. That NSX was a beautiful car. Great to watch TY!
The power is so hard to compete with
In their early days I could fend them off
Now
No way
So I have fun rattling them and then getting good video for them !
Now
No way
it seems you are having a hard time getting power down one the slower corners.....how stiff is your rear bar set? I found when I disconnected the rear bar in Casper I could get on the throttle much earlier and harder, especially in bumpy corners! It felt like the rear suspension was working better, vs skipping around with the rear bar on.
Or maybe crank up your rear wing a little for Sears?
It was coming apart... had to make sure it was attached. just being safe.
my lucky key chain! .... so yes it was necessary. the key chain is my g load meter.
it seems you are having a hard time getting power down one the slower corners.....How stiff is your rear bar set? I found when I disconnected the rear bar in Casper I could get on the throttle much earlier and harder, especially in bumpy corners! It felt like the rear suspension was working better, vs skipping around with the rear bar on.
As far as the power being put down.. are you seeing issues at 11 ,5, 2 or 7?
the rear bar is the stock bar, slightly stiffened. so not bad. some of those slow corners, the exits are off camber or the turn is over 90 degrees . combined with 8 heat cycle A6s.... it puts a little delay on the throttle appl. the 928 is not as nimble and dosnt have the power as the cars i run with. you have to understand, the 3 cars i ran with in that race. NSX 650hp., NASCAR 760hp, and that transam car (rumored , 700hp). So, it might appear that I'm not on the gas, but with near half the HP, its a huge disadvantage. plus, not having real slicks puts a damper exit throttle too.
even the transam car of Bob Davis was having problems entering and exiting the slow turns.
it was popping out of second for a few years. (without load) had to do with a shifter fork alignment.. so the answer is no.. only 1st and 2nd are on the same shift fork. I re-aligned it, but it felt funny in the warm up lap, so as a precaution, i put pressure on it. as long as the hands are aligned correctly, and you are strong enough, it is not a problem.. so,it is not a problem. as far as the shifter goes, it was the stock shift boot that was disintegrated internally , so have to replace before next race.
