The Power of ProCoach
there is no reason to sacrifice 30-75hp for several seconds, up to 4 in this section and up to 8, over a lap , by being in the non optimal gear. (not to mention the added control by having the RPM in the higher range during turn entry) if you have one... im interested to hear it.
Lower gears for better HP utilization (and control) is the hall mark of racing (road or drag)
When i coach for speed /lap time, this is just one of the tools i use, Peter may have others , but when mine are used, gains are made ,its that simple. anyone that does race or knows how to decrease lap times or segment times can attest.
Basic Site Sponsor
Basic Site Sponsor
Received 2,834 Likes
The tip is very old. Visible in Skip Barber's video by Carl Lopez many, MANY years ago. If Bruce MacInnes is there, ask him. He taught it to me. Data confirms it.
This is a pretty faithful execution of what I talk about with drivers I work with at LRP. Ben had never raced a car before beginning work with me in 2010 at Summit Point, now he's one of the best I've ever worked with.
Start at 8:30, where he is following the legendary Rick Bell, one of the masters of Lime Rock for forty years, in a Formula Atlantic (400 lbs lighter).
This car is 70-135 bhp down on the others (different class), has a fair bit of understeer (he could do better carrying the brakes in longer to get the car to turn quicker), but the geometry is, for the most part, correct...
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
+1 that's it right there !!
There is a video that explains this on youtube. It was done in an mx-5 in iRacing, but how to approach turn 3 (as well as the rest of the track) is explained.
Basic Site Sponsor
Basic Site Sponsor
The latter approach would makes you slower, later in the turn. Precisely the opposite of what you want in order to optimize the Right Hander onto No Name.
Adam, have you raced or driven at Lime Rock, other than virtually? Just a question...
Basic Site Sponsor
Basic Site Sponsor
Not only that, but the radius of this corner is ANYTHING but constant...
There is the seductive entry. Then, the "stretched," middle center section where most are "dead in the water." Then, there is the trick, tightening end, culminating at the end of the inside curb...
No, your "trick" is what was a quarter of a second slower in the OP's original comparison. Driven by someone I respect very much and who knows that place.
Basic Site Sponsor
Basic Site Sponsor
You're saying the straight doesn't matter? And that there's a difference geometrically in the line between the faster car and the slower car? Nah, that's ok. You do your thing and I'll do mine...
The car did near 1:00.XX flat with the previous owner and previous setup, without "shifting down." These laps are some ways off that. The new shop, of course, has a laundry list of changes they'd like to make, but as we know, there's always some tangible gain in the driver due to comfort, confidence and learning the timing of control input versus response.
https://youtu.be/1E0In7QrOM8
so if he ran a 1:00 , he might run a 59.5 using my advice. You wont know until you try it and see the data.
coincidentally, your video makes my point exactly AND the RPM range is the same as it is for the CaymanR. keeping the RPM in the 6k range is what he does and what the OP should do as welll. notice how he approaches turn 1 and the slow sections after. all downshifting, and keeping the RPM in the 6k range. again, by not downshifting to 2nd in this area, you run the car at a 50 to 75hp deficit for a substantial amount of time when the wheels are straight. having the car in the 4000rpm range for the caymanR or 3500rpm for the boxster, is just a waste of the HP you have available and will decrease segment times and lap times
Peter, you and I are totally on the same page. And coincidentally we have both driven, raced, and coached Lime Rock. Imagine that!
Basic Site Sponsor
Basic Site Sponsor
Really the idea is to create your own ideal line with the given track. You could do this with 3 cones per corner. One where your entry starts, one at the apex, and one final cone where you are driving straight again. If there is space between the final cone and the first cone of the next corner then you have a "straight." Your "straight" might only be 30 feet of driving diagonally across the track sometimes through.
I'm not really sure why you are trying to argue with me though. Rick Bell in the video that you used as an example is doing as I've described. Why are you so mean sometimes? I've never came on here and said you or anyone else was wrong about anything. I just try to help people understand the why behind all this as that part very much interests me.
