What Loud Squealing Cold Pagid Yellow Racing Brake Pads Sound Like (Cayman)
#32
that isnt exactly true... i can provide a process that assures no squealing, even with 6 months of street driving. its all in the bedding process. what you say is true though.. however, its a distant relative to the real solution. proper initial bed in. again, this is 20 years of doing this with NO squealing for track and street duty.
#33
A German car that does not have squealing brakes has no brakes.
#34
Kibort Braking bedding procedure. In all seriousness- Pagid go through stages it seems. I don't run them anymore. Even with PFC's I'll get squeal it seems at times. I always use to run floating rotors -which just adds to the harmony (but I hate Giro Disc- sorry) . Back right now to just nice Deman Rotors. Lasting forever it seems. Mark must know the secret.
#35
PM sent.
#36
Mark, I'll consider your procedure if you could PM me it. But that transfer layer on my rotors is pretty obvious after racing or solid track sessions . I may not swap out my pads but I do swap wheels and tires between track and street so get a good look each time. It's easily noticed through the wheels too when it starts to wear off again as it is patchy (well, more streaky really) for a few days before it fully disappears again.
Granted, some pads (sintered ones, and maybe carbon or ceramic based if not using an organic resin binder?) might perhaps not produce that transfer layer on the rotors when hot, but my Pagids do, and they do run quiet while it lasts.
Thanks for sharing that. Been wanting titanium shims to better protect my pistons - and so fluid - from pad heat (and ideally ceramic calipers) but have held off, mostly just as it is already tight there when fitting new endurance pads.
I've ran PFC08's and PFC11's on OEM and Girodisc rotors (without using the OEM vibration dampers) - they always squealed like a banshee on the street between track days. This year I actually tried using Girodisc titanium shims hoping to keep some heat away from the piston seals but as an unexpected surprise the PFC11 pads were silent on the street and track. I can't say this is definitive but it seems like the shims act similarly to the OEM vibration dampers that usually attach to the pistons.
Anyone else have experience with shims?
#37
there are all sorts of theories out there, but this is what I have observed and the proof is in the experience. anyone that has been racing with me and shares a pit and repair activities, has NEVER heard a squeal at the track or on the street. glad you think it is worth a try . anxious to hear how it works for you. PM sent.
Mk
#39
Ill PM you now and let us know how it goes. if you just put them on recently there is still a good chance you can fix the noise. rotors are in new or near new shape?
#40
Registered User
#41
Mark. I think you are incorrect. RS29 Black are not the endurance pads. Yellows are. 29's were the pads I was referring to that go through stages. YOU could not keep them quiet. New rotor or old?
#42
My new Pagid yellow pads started squealing a few days after being installed along with new rotors a year or so back. Porsche mechanic's previous break-in instructions were to not do any hard braking until I had put some miles on them. After a few more days I did three or more panic stops form 60 mph to almost "0" on an open stretch of the freeway and the hard braking rubbed off whatever was causing the vibration. I do the same procedure on my mountain bike when trail grims builds up on the disk brakes, and same on my pickup, when I start hearing that squeal. Now after a year, every few months I hear squeals, do the same hard breaking, and the squeals disappear for a while. It appears to me to just be accumulated brake dust and grime. Give it a try.
#43
its a very high frequency "bite and release" that creates the noise. when the rotors are clean and pads are bedded properly, you dont have that.
Mk
Mk
The RS29s are the wild card.. they are pretty hard and its the one type of pad i havent tried. (endurance pad) however, i was told that the EBC Orange is a similar pad and it was one that took a lot of effort to bed properly... and even that was successful on the performance street car i own as well. (14" rotors , brembos , etc)
It takes a serious bedding procedure (the kind that would see me pulled over on road) or serious track laps to shut them up for even a day. Even an autocross day a month or two back (won, so wasn't hanging around) didn't get them hot enough to quiet them for even that long.
#44
FWIW, endurance yellows squealed on my OEM rotors, and then the same on Sebro slotteds - despite the slots theoretically helping to keep the pads clean.
#45
I never said that the RS29s were "Black". the RS29 are the endurance pad. (yes, they are called "yellows" )
