What Loud Squealing Cold Pagid Yellow Racing Brake Pads Sound Like (Cayman)
^^ I'm sorry, but it is simply false to lead folks to think that track pads will not squeal when bedded properly. There are hundreds of posts about folks not being able to stop track pads from squealing. I doubt hundreds are all wrong or bed them in all wrong.
Track pads - racing pads meant for high speed or high power braking - are built for the track and don't work as well on the street. Braking performance is one reason. Noise is another. It's just a fact.
Now there are hybrid - or middle ground pads - that can serve dual purposes, and plenty of track pads don't squeal. But in general, no, bedding properly is not the surefire way to stop squeal.
Again, im not making this up.... 20 years of dual street and track use, no squealing. single piston porsche or 4 piston brembo on every type of rotor imaginable.
yes, 100s if not 1000s are not doing it right. race pads work perfectly on the street, even when cold. never had a hint of a problem in performance. again 20 years of no squeals... track and street duty. . Now, do you want to know how?
Well, you can either accept it, watch my vidoes, try and find a squeak, ANYWHERE, on the street or track, and then ask, how i do it, OR you can fight it and NOT wonder what im doing differently to allow use of anything from a pagid orange to a ST41 on the street or track and not ever have a squeal again.
Well, if i can do this for 20 years , over many many of sets of race pads, and you cant, maybe im more "special" than you. seriously though.. there is a method and you might want to know how do to it.... I've done it and its not just on my own racer , its on others as well. the method address the root cause of the squeeking, which is a vibration frequency. its all about getting the surfaces of the pad and rotor to be matched near perfectly. traditional pad bed in, doesnt do it.........and if its not done correctly, the imperfections follow over the life of the pad and rotor. (thus the noise)
Adding this as a reference for new guys who are considering race pads for their mostly street car,
and are curious what squealing cold racing pads sound like. I've always wondered.
https://www.youtube.com/watch?v=qgSjmZIPSfQ
Some race pads will squeal no matter what you do when you drive them on the street. And some street pads will get too hot and fade on the track no matter what you do. Different designs have different capabilities.
My street pads never made any noise. My Pagid pads used on the track squeal on the street. Par for the course.
My RST2 fronts and RSL29 (or maybe RSL19?) rears were chamfered (front and rear edges bevelled at 45 degrees and very thoroughly bedded per Pagids instructions for race pads. If anything they were over bedded as I ran that procedure twice - I wasn't happy with the shallow depth of the white layer and the relatively small volume of fumes coming off the first time. But a day or two on street and they start to squeal again, so I looked into why.
Beyond conditioning the pads themselves, beddding also puts a transfer layer of pad compound on the rotors. This means that freshly properly bedded pads and rotors are essentially braking via pad compound to pad compound contact rather than pad compound to bare steel rotor surface. So they are quiet and don't squeal.
If your car is a track only car, your brakes spend most of their time in the ideal operating temperature range for those race pads, that pad compound transfer process keeps happening during use (pads get hot enough for a film to stick to the rotor) , and you get little or no squeal.
But if your car is then used on the street afterwards, those race pads don't get properly hot often enough to maintain that transfer layer. Instead, the pads run too cool, and operate primarily through mechanical friction rather than compound to compound 'stiction' - the rapid breaking and reforming of the compound's molecular bonds at the interface. That mechanical friction rapidly scrapes that transfer layer away to leave a near naked rotor surface. This mechanical friction dominance at lower temps leads to friction induced squealing, and to accelerated rotor wear.
As Mark says, you can rebed your pads (well rotors really - as sufficient hot braking puts a fresh transfer film on them) at any time to beat the squeal. My car is quiet for a day or two after tracking or racing her for instance. But unless you have a tight and twisty canyon handy on your daily commute, that's hard to keep up.
In my limited experience with (well bedded) street pads on track, pad fade has been less noticeable than massively accelerated pad wear compared to race pads. Three or four times faster wear when run at race temps, so they can die within an hour or two of track time. Then yes, finally massive and fairly sudden fade when they wear down to the thermal backing layer or just get too thin. Makes for excitng times if you do run out of street pad. Sometimes the backing plate gets hot enough to fuse to the piston by melting around it, as it did in our Integra once:
DE sessions are usually kept short, which keep temps safe for street pads, but its always a good idea to keep an eye on their wear rate, especially with longer sessions. That wear rate accelerates as they get thinner, and I've found that the last 3/16ths or so disappears real fast on sustained track sessions if we haven't kept ahead of it by swapping on new pads.
My experience too. Pad compounds are like tire compounds - they have an optimal operating temperature range.
high speeds, will remove the film to bare metal. it has to do with the high temps and the pressures involved.
again... this the main Pagid versions (RS14, R-4-4) porterfield, raybestos, st41 performance friction (PFC11, 01, 08), etc.... they all can be bedded, used on the track and street with little or no notice operational differences on the street vs real street pads.
if you have any doubts. i have my car that just came off a trailer from a laguna seca race weekend.... Equipped with very aggressive PFC11 pads.... ill drive it around on video if you want. apply any brake pressure, go any distance, and nothing will change. there will not be a noise and there will be no exceptions.
GoBlue! (05-12-2023)
I've ran PFC08's and PFC11's on OEM and Girodisc rotors (without using the OEM vibration dampers) - they always squealed like a banshee on the street between track days. This year I actually tried using Girodisc titanium shims hoping to keep some heat away from the piston seals but as an unexpected surprise the PFC11 pads were silent on the street and track. I can't say this is definitive but it seems like the shims act similarly to the OEM vibration dampers that usually attach to the pistons.
Anyone else have experience with shims?
its all in the bed in process. Sure there are things to reduce the noise, but to cure it, its a bed in process.
No matter how well you bed them in, street driving will eventually get you squealing again. Just hammer your brakes now and then and the squealing will go away. This is normal.
The hammering I refer to is not the same as a normal full bedding procedure. Just get some real heat in them now and then. Check your mirrors.
WRONGLY ACCUSED!
Received 3,237 Likes
Why would you run yellows on the street if the squealing bothers you? It takes about 20 minutes to swap out pads.
I leave my track pads on my 944 and it squeals a little from time to time. Who cares?
