Performance Friction V3 rotor/hats for SPC in stock at OG Racing
Old 04-04-2017, 05:32 PM
Carrera51
Carrera51's Avatar
Default Performance Friction V3 rotor/hats for SPC in stock at OG Racing
Guys:
Want the ultimate in two piece rotor/hat technology for your Spec Cayman? We have the latest Performance Friction V3 rotors and hats in stock for the Spec Cayman. These also fit the 996 and 997 Carrera. No more bobbins, or nuts and bolts to attach the rotor to the hat. The unique and simplified design reduces weight and makes changing out the rotors easy.
Rotors are the same diameter and thickness as OE and are legal for Spec Cayman. They are in stock and ready to ship.
http://www.ogracing.com/performance-...ter-cayman-s-2
If you have any questions, give us a call at 1-800-934-9112 or email us at info@ogracing.com
Old 04-04-2017, 06:16 PM
wellcoached
wellcoached's Avatar
can you post the actual weight of these ?
I dont see rears, are they coming?
Old 04-04-2017, 06:56 PM
Carrera51
Carrera51's Avatar
The fronts total weight is 16.1 lbs each. As of now, PF hasn't produced a rear. They didn't in the V2 design so not sure if they will on the V3.
Old 04-04-2017, 07:07 PM
wellcoached
16.1 is total hat & rotor combined , correct ? did you guys actually weigh or is that a PFC spec ? Hats are steel i assume ?
Old 04-04-2017, 07:12 PM
Carrera51
Carrera51's Avatar
Sam:
16.1 lbs is the total weight of a single rotor/hat assembly. We removed if from the box and weighed it on our scale we use to weight packages for shipping. V3 hats are aluminum.
Quick Reply: Performance Friction V3 rotor/hats for SPC in stock at OG Racing
